Snapper 820-auger shaft - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 09-29-2016, 04:30 PM Thread Starter
Hello all! Hope fall is treating you well, we all know winter is right around the corner!
Started working on an old snapper 820 a couple of months ago and just got around to putting the finishing touches on it. So, today I went to check the differential fluid and the auger shaft spun out and I'am not 100 percent sure on how to reassemble it. I attached some pictures of what I'am talking about. It looks like the shaft auger should slide over a woodruff key, but I don't see where any would go.
Any advice would help!
Dustin
ID:	89857   Click image for larger version
ID:	89865   Click image for larger version
ID:	89873   Click image for larger version
2005 MTD Yard Machine 26inch-8hp
1971 Arines-Sno-Thro-24in-7hp
2001 Craftsman-22"-5hp
dhoyt714 is offline
post #2 of 3 Old 09-29-2016, 05:45 PM
Thanks (Received): 7
Likes (Received): 8
Maybe this parts blowup helps? It does look like there is a woodruff key, #15.
https://www.partstree.com/parts/snap...earbox-shafts/
EdwardC is offline
post #3 of 3 Old 09-29-2016, 06:29 PM Thread Starter
I saw this online but it dosen't show an woodruff key in the number 16 worm gear even though it has a spot for in the picture. I don't know if the gear was just worn in before and that was all that was turning the auger or if the key broke years ago.
dhoyt714 is offline
