Roper friction disk - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 10-13-2016, 06:13 PM Thread Starter
Roper friction disk
I'm trying to find the part number for a friction disk from a 6-24. Does anyone know were to get this or if there are any substitutes?
Snapper 422 is offline
post #2 of 4 Old 10-13-2016, 08:13 PM
Likes (Received): 20
I have one or two of them laying around. I'll compare them to some others and see if they match anything more common.
sidegrinder is offline
post #3 of 4 Old 10-15-2016, 01:23 PM Thread Starter
Any luck?
post #4 of 4 Old 10-21-2016, 08:05 AM
Likes (Received): 345
I think unless you're extremely lucky, you will not find an oem friction disc for that Roper. What I did find was there was one for a Toro that had the same overall dimensions but was not a 'bolt-on' install. This was on a Craftsman labeled blower that I'm fairly sure was a Roper built unit.
What I did was chuck it into a metal lathe and opened up the center hole to fit the shoulder of the mounting fixture in the blower. Once that was done, I then was able to clamp them together and drill and countersink new holes for the mounting bolts. It ended up working out for me. I don't think it would be that expensive to have a machine shop make the modifications for you if you don't have your own tools to make the modifications.
Good luck
HCBPH is offline
