Ariens S724 Gear Shifter Stuck, can't move it manually. - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 10-21-2016, 02:15 AM Thread Starter
I have an Ariens ST724 I'm in the middle of a predator engine swap, I wanted to also fix the gear issue, It seems the shift knob is stuck in reverse. I tried prying, hammering, lubricating the drive shaft but it still won't move. It appears that the nut is blocking movement but I'm not 100% sure on that. Anyone have any suggestions to free the shaft? Here is a video where I discuss the problem in depth, and rant a bit
zml661415 is offline
post #2 of 3 Old 10-21-2016, 09:44 AM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
It is Frozen on the shaft. Take a wire Brush, Wheel, or sandpaper and clean what part of the shaft is visible. Heat the shaft with a torch, and it will break free with some persuasion and PB Blaster. I use a piece of 2x4 and a hammer so as not to damage anything. It may take some patience, but will break free.
Jackmels is offline
Thanks zml661415 thanked for this post
post #3 of 3 Old 10-22-2016, 05:01 AM Thread Starter
Thanks so much!! After heating it, wire brushing it, and hitting it with more PB, I hit it with a flat head and hammer right on the metal bracket not on the friction disk and was able to free it!
