Ariens 8hp Snowblower impeller shaft slack - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 11-12-2016, 04:33 PM Thread Starter
Ariens 8hp snowblower model 924050 has slop in the driveshaft from the impeller to the auger gear box.
The auger shaft seems ok no extra play in any direction.
Does this sound like the gear on the shaft and in the auger box is bad?
Everything does work just noisy.
Pulley for impeller and auger does appear to be all the way forward,but if you move the impeller it will move about 3/4 inch back and forth.
Thanks...............
hdman97 is offline
post #2 of 5 Old 11-13-2016, 07:41 AM
Thanks (Received): 195
Likes (Received): 816
Replace the Bearing and then Judge, Ariens 54063, 05406300 | Ariens 54063
Jackmels is offline
Thanks hdman97 thanked for this post
post #3 of 5 Old 11-13-2016, 04:47 PM Thread Starter
Thanks for the response Jack.
So you think a bad main shaft bearing would cause the forward movement of the shaft to the gearbox?
Haven't pulled it all apart yet,but will check that.
Thanks again
hdman97 is offline
post #4 of 5 Old 11-13-2016, 10:51 PM
I am thinking the bushing inside the gearbox is bad. There is a collar on it that acts as a shim.
post #5 of 5 Old 11-14-2016, 05:15 AM
Stebekk is offline
