advice needed on HM80 loose magnets on flywheel - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 11-25-2016, 04:58 PM Thread Starter
I bought an old snowblower with a Tecumseh HM80 engine. (model HM80-1551 27B S/N 5258D) The inside diameter of the flywheel has rusted badly including under the magnets so they are no longer attached to the flywheel. I sanded the rust lightly but cannot find any witness marks showing where the magnets should be.
1. Could someone give me the angular location of the magnets relative to the keyway? Is there a space between the two magnets? Should the magnets be flush to the edge of the flywheel nearest the engine?
2. Any suggestions to bond the magnets to the flywheel? I was going to use J-B WELD for steel hoping it could handle the vibrations.
mcgyver is offline
post #2 of 3 Old 11-25-2016, 05:29 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 418
Likes (Received): 664
i would consider giving up on that flywheel and sourcing a good used one. or.
https://www.snowblowerforum.com/forum...ator-sale.html
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #3 of 3 Old 11-25-2016, 06:15 PM
Thanks (Received): 212
Likes (Received): 767
JB weld is what I use to reattach magnets, but it is usually obvious where they go from the old glue on the flywheel. Get a used flywheel just to use as a reference.
cranman is offline
