Single stage - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-06-2019, 06:19 PM Thread Starter
Single stage
Hi just looking for some feedback on a single stage unit, opinions on what to get for the light stuff. I have the Ariens Deluxe 24 for the serious snowfalls. Anyone have opinions on any of these newer electrics? I prefer Gas but looking for some advise from the members.
pete300 is offline
post #2 of 12 Old 01-06-2019, 07:21 PM
gibbs296's Avatar
Thanks (Given): 161
Thanks (Received): 65
Likes (Given): 1157
Likes (Received): 272
Anything Toro or Honda for a gas single stage will be good. Most of the electrics don't take the snow down to the pavement, so therefore lack partial self propulsion.
gibbs296 is online now
post #3 of 12 Old 01-06-2019, 07:47 PM
GAR
GAR's Avatar
Thanks (Given): 68
Thanks (Received): 18
Likes (Given): 248
Likes (Received): 150
For the light stuff or just cutting paths in the backyard for the (little) dogs we have I use a Toro Powelite or my Honda HS522. I love the Honda starts easy, takes regular gas and clears down to the pavement. The Toro is a two stroke so mixing gas in a separate container is sometimes a pain but the machine is super light and dose an amazing job for its size.....Really can't go wrong with either the Toro powerlite or Honda hs522 as backup blowers.
"When I no longer thrill to the first snow i'll know i've grown old"
GAR is offline
post #4 of 12 Old 01-06-2019, 08:29 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
20 yr old toro ccr2000 2 cycle i brought back to life blowing heavy wet snow, was easier using this than my 28/10hp monster. buy gas for longevity, batteries are only good for x amount of years/charges and arent cheap to replace
MY VIDS ON FIXIN HER UP
vinnycom is offline
Thanks gibbs296 thanked for this post
post #5 of 12 Old 01-06-2019, 08:31 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
There is no one on here that doesn't like a 2 stage but the caveat consensus, they don't do everything, heavy wet snows are difficult.
JLawrence08648 is offline
post #6 of 12 Old 01-07-2019, 08:57 AM Thread Starter
Thanks for all the info it will help me decide on the next unit.
pete300 is offline
post #7 of 12 Old 01-07-2019, 10:02 AM Thread Starter
I found a Toro CCR 2000 online for $100. bucks. Not sure on its condition yet. Going to check it out.
pete300 is offline
post #8 of 12 Old 01-07-2019, 10:37 AM
Thanks (Given): 95
Likes (Given): 73
Though Honda and Toro are the best, any single stage will work fine. Hondas start right up and are 4 cycle. They have a built in shut off valve, choke, but no primer, and heavy! Very heavy! However to replace the carb is a lot of work. Other 2 cycles are easier to replace the carb with Toro being the easiest. I like the belt on the Toro. 2 cycles are very light. I have a Snapper, Toro 2000? and 2450, 3650, and 210, and MTD made. All work well and will do the job.
post #9 of 12 Old 01-07-2019, 10:55 AM
Thanks (Received): 80
Likes (Given): 67
Likes (Received): 248
i haven't used a new electric one but did use one a few years ago and they do ok and beat shoveling but don't compare to most gas ones. if you do get a 4 stroke single stage blower make sure it is at least 5hp or more. i had a 3.5hp honda single stage for a very short time and it didn't have enough power to really move snow well.
yardworks 31AH6WKF515
crazzywolfie is online now
post #10 of 12 Old 01-07-2019, 08:50 PM
Likes (Given): 7
Likes (Received): 14
Not sure on electric, but my Toro 721 R-C is a very aggressive machine. Took 4 seasons of heavy use on uneven concrete drives and walkways to wear down the rotor blades and scraper bar. I just changed the scraper, both blades, plug and belt (belt didn't need to be) for about $130 (parts from dealer).
Stability is offline
