1964 snowbird - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-31-2016, 10:11 AM Thread Starter
1964 snowbird
looking for a carburetor/gas tank assembly for an 1964 snowbird snow thrower. #100202-0169-01-6310021
I was able to locate a gas tank but feel it would be better to have both as an assembly.
gordy5756 is offline
post #2 of 7 Old 01-31-2016, 10:29 AM
GAR
GAR's Avatar
Thanks (Given): 68
Thanks (Received): 18
Likes (Given): 246
Likes (Received): 150
I am know expert on the snowbird but I have a carb and gas tank off a 5hp briggs that looks to be the same. I used the numbers you posted and found a Sears part direct that show this carb and gas tank set up.
GAR is online now
post #3 of 7 Old 01-31-2016, 11:01 AM
Big Ed's Avatar
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
Hi,
What model is the Bird? S225....S226?
Do you have the old carb?
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #4 of 7 Old 01-31-2016, 11:45 AM
Big Ed's Avatar
Thanks (Given): 10
Likes (Given): 9
Question
Knock Knock Gordy are you sleeping?
What is wrong with the carb (if you have one?)
Not much to them, I think this is your carb?
Click to make larger, maybe you could fix the old one if you have it?
What is the problem?
22" Dual Stage
22" Dual Stage
Big Ed is offline
post #5 of 7 Old 01-31-2016, 11:48 AM
GAR
GAR's Avatar
Thanks (Given): 68
Likes (Given): 246
Attachment 76569
Big Ed, that carb set up sure dose look like the one I posted picture of.
GAR is online now
post #6 of 7 Old 01-31-2016, 11:53 AM
Big Ed's Avatar
Thanks (Given): 10
Likes (Given): 9
Parts numbers,
Click on me, I don't know if you know this.( hold the control button and the plus at the same time to read it better after you open it)
22" Dual Stage
22" Dual Stage
Big Ed is offline
post #7 of 7 Old 01-31-2016, 11:58 AM
Big Ed's Avatar
Thanks (Given): 10
Likes (Given): 9
Yes it does, it is not the blower that really matters but the engine.
That should be his?
When he wakes up maybe we will know.
Not much to working on them?
Maybe clean the needle valve, or it needs a new diaphragm?
If he even has it?
22" Dual Stage
22" Dual Stage
Big Ed is offline
Likes GAR liked this post
