2015 Toro Snowmaster 724 QXE review - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-31-2016, 03:46 PM Thread Starter
Thanks (Received): 21
Likes (Received): 50
I purchased Toro's new design 724 QXE in October 2015 and did not get a chance to use it until mid Jan 2016 due to a mild winter in NJ. It started in less then a second of cranking with the electric start and hummed to life. These Lorcin engines are smooth as silk. We got 22.5" of snow and at least 30" drifts. No break in for this machine, it went right into blowing the 22-30" snow without a whimper. It throws the snow at least 25-30' and moves along at a quick pace. The personal pace works great and if you grab the PP handle right, the front end does not raise up making sure you are scraping right down to the concrete. With the auger pulling you along and the drive wheels, this machine is unstoppable. The auger spinning at such a fast speed insures that clogs are not going to happen coming out of the chute. The joystick for controlling the chute outlet works well but takes some getting used to to make it do what you want sometimes. The machines sips gas at a pretty slow rate so you want be filling up for a while too. The beauty of this new design hybrid is that it looks like a two stage but is really a single stage. If you want a machine that can do more then a single stage but don't need a huge, heavy and slow moving two stage this is the machine for you. It fills the place solidly between a single stage and a two stage quite nicely. Nice job, Toro!
ID:	76705   Click image for larger version
NJHonda is offline
Post Thanks / Like - 5 Thanks, 4 Likes, 0 Dislikes
Thanks micah68kj, Excitabletom, Zavie, NewShockerGuy, leonz thanked for this post
Likes 1894, detdrbuzzard, leonz, micah68kj liked this post
post #2 of 14 Old 01-31-2016, 04:04 PM
GoBlowSnow's Avatar
Thanks (Received): 82
Likes (Given): 56
Likes (Received): 247
great review!
GoBlowSnow is offline
post #3 of 14 Old 01-31-2016, 04:55 PM
Thanks (Given): 135
Thanks (Received): 267
Likes (Given): 358
Likes (Received): 903
I've been waiting to hear about this machine. Good job with your review.
micah68kj is offline
post #4 of 14 Old 01-31-2016, 05:09 PM
69ariens's Avatar
Thanks (Received): 38
Likes (Given): 53
Likes (Received): 100
After owning an old reo single I did not have much hope for these new singles but after watching all the new vids from the big storm I am very impressed. Thanks for the wright up.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #5 of 14 Old 01-31-2016, 07:24 PM
Zavie's Avatar
Thanks (Given): 43
Thanks (Received): 76
Likes (Given): 307
Likes (Received): 156
Glad to see Toro got it right. Nice review. This would be the prefect blower for my neighbor. It's great to see my first impressions of the machine were totally off base. In real life it looks like it can keep up with the big boys.
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #6 of 14 Old 02-06-2016, 02:23 PM
NJHonda. I live in Bucks County, PA. So pretty close. I'm very close to buying a new snowblower and had my heart set on a Toro 2 stage. My question: were you looking at the 2 stages also? I'm torn between the 824 QXE and 826 OXE. I feel like the 826 OXE if tougher and a machine that's more capable. Your thoughts?
mikebby20 is offline
post #7 of 14 Old 05-17-2016, 09:15 PM
Originally Posted by mikebby20 View Post
...I'm very close to buying a new snowblower and had my heart set on a Toro 2 stage. My question: were you looking at the 2 stages also? I'm torn between the 824 QXE and 826 OXE. I feel like the 826 OXE if tougher and a machine that's more capable. Your thoughts?
Look for a youtube video titled "Toro Snowmaster 724 broken belt replacement". The belly plate been removed showing off the plastic enclosed transmission and the other housing.
I would be concerned on any maintenance or repairs that maybe needed in 10+ years. Recommend you spend a little more and consider a two stage blower with the old fashion transmission - you should be able to get more years out of it since the maintenance / repair should be easier (and cheaper). I would look for zerks fittting on the auger/impeller so it's easier to apply the annual greasing.
BrooklynDaddy is offline
post #8 of 14 Old 05-23-2016, 11:48 AM Thread Starter
Sorry I missed this.. This machine is just what I dreamed of. A 2 stage is too big and heavy to maneuver quickly and way too big to put away in the basement every summer like i do with this one. Trust me,. One your buy this machine you will never consider a 2 stage again unless you are in the egreat white north and 30" + are the norm. up to 15' inches and this 724 did not even bog last winter. This machine will last me 10-15 years no issue. Absolutely no need for a huge heavy 2 stage. Trust me on this. I have used many 2 stagers and this Toro is a dream to handle as compared to them. And watching that belt change vid, itys a 15 minute job. Easy. And its a huge belt so don't expect to be replacing it for quite a while
NJHonda is offline
post #9 of 14 Old 08-29-2016, 06:06 PM
Thanks for the review.
garthg is offline
post #10 of 14 Old 11-10-2018, 11:30 AM
I bought the Toro 824 last year, I've been a big Toro fan for years. Dry powdery snow, blasts right thru, clears down to the pavement, no issues at all. Here on Long Island,NY we occasionally get wet snow and as long as it's "virgin" on the ground, the machine had no issues. Trying to deal with the piles at the end of the driveways from the plows, the shoes just lift the blower up over it and you can't clear down to the pavement. So, if you always have light fluffy flakes, it's an excellent machine.
IslandMan54 is offline
