Why can I edit someone elses post - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-21-2020, 05:33 PM Thread Starter
Likes (Received): 22
I hate those shovels. I took mine off when I did the impeller mod thinking I wouldn't need it anymore. Wrong the mod does a hec of a job but it isn't 100 %
BlowerMods1 is offline
post #2 of 5 Old 01-21-2020, 05:43 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
You shouldn't be able to edit someone elses post. But now I see you've edited your own post.
The thread was https://www.snowblowerforum.com/foru...ml#post1714701
post #3 of 5 Old 01-21-2020, 05:49 PM Thread Starter
Yep. This thing is going crazy. I clicked on the post and it opened up in the edit mode, thought a moderator would check it out.
post #4 of 5 Old 01-21-2020, 05:55 PM
Thanks (Given): 590
Likes (Given): 4371
If you can open up and edit someone elses posts you already have Moderator approvals so it'd be an Administrator who would likely need to check that out for you.
Hence the reason I moved your post here.
post #5 of 5 Old 01-23-2020, 02:00 PM
Let it snow
Administrator's Avatar
Thanks (Given): 11
Thanks (Received): 108
Likes (Given): 28
Likes (Received): 54
Do you still need help with your account?
-Philip
If you need admin support please post here:
Administrator is offline
