Oil questions on a Predator Generator - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-01-2016, 01:38 PM Thread Starter
Elt31987's Avatar
Thanks (Given): 44
Thanks (Received): 14
Likes (Given): 235
Likes (Received): 47
My Predator calls for 5W-30 in the winter and 10W-30 in the summer. So 2 questions really. When i switch it over to 5W, lets say i dont use it ONCE this winter and summer comes around. Can i just drain that back into to the container for next winter and do the same with the 10W when winter comes again? And is it possible, safely, to run one of these weights year round when using Mobil 1 Advanced or should i really drain it twice a year?
2016 Ariens Deluxe 28 SHO AX306cc (921044) | Drift Cutters | Front Weight Kit | Handwarmers
1965 Ariens 10ML60D with 1970 10,000 Series Sno-Thro Attachment 10995 | Tecumseh H70-130216G (7HP)
2016 Ariens Razor SP Mower AC159cc (911175)
2016 Predator 8750 Peak/7000 Running Watt Generator 13HP 420cc (69671)
Elt31987 is offline
post #2 of 3 Old 12-01-2016, 03:09 PM
Likes (Received): 280
They say oil does have a shelf life..... but I wouldndt hesitate to just swap them back and forth if you have real low hours on it. A genset just doesn't see much action under normal circumstances. I'd go every few years on adding new oil unless you ran it for extended periods. If you use synthetics you could easily go longer...... this site is a great resource for all things oil: https://www.bobistheoilguy.com/forum...s.php?ubb=cfrm
Thanks Elt31987 thanked for this post
Likes Elt31987 liked this post
post #3 of 3 Old 12-02-2016, 07:45 PM
Likes (Received): 22
I would think you could just run the 5w30 year round since the w actually stands for winter to reference how well the oil will flow in colder temps at start up. When it's warm out or when the engine reaches running temp both those oils will perform the same. Or you could mix the two and end up with 7.5w30
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
