Rust penetrant - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 03-11-2017, 12:06 PM Thread Starter
2badknees's Avatar
Likes (Given): 23
Likes (Received): 13
Rust penetrant
I've been in touch with some motorcycle guys that use a 50/50 mix of tranny fluid and acitone. They claim it works the best and should be mixed in small amounts because the acitone tends to evaporate.
I haven't tried it
2badknees is online now
post #2 of 14 Old 03-11-2017, 12:52 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
I heard about this on the website BobIsTheOilGuy. It's a very popular mix.
JLawrence08648 is offline
post #3 of 14 Old 03-11-2017, 02:19 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
Agreed, works well.
drmerdp is offline
post #4 of 14 Old 03-12-2017, 06:05 PM
Thanks (Given): 587
Thanks (Received): 766
Likes (Given): 4349
Likes (Received): 1734
Haven't tried the tranny acetone yet but I do keep a few cans of PB Blaster on hand as it's just wonderful (IMHO). If anyone is using WD40, it's not really a penetrant but it's better than nothing. I use WD40 for tool cleaning.
Edit: I keep forgetting that WD40 came out with a Penetrating Oil. That product I haven't tried. I was referring to the "regular" WD40 that some folks use for everything.
post #5 of 14 Old 03-12-2017, 11:01 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1579
Likes (Received): 1663
pb blaster has worked for me on almost every occasion. might try tranny/acetone for something that the PB does not work on to test.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #6 of 14 Old 03-13-2017, 07:28 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
ATF/Acetone works really well. Kroil and liquid wrench are also pretty good. Marvel Mystery Oil also has some "rust-melting" properties.
('87 Toro 38150 826)
post #7 of 14 Old 03-13-2017, 07:38 AM
clamdigger's Avatar
Thanks (Given): 8
Likes (Given): 12
Likes (Received): 21
If your willing to try home made concoctions, you could go really "old school" and give iodine a try. I first started working on aircraft with the CP107 Argus, it used Wright Cyclone Turbo Compound R3350 18 Cyl engines, when one of the 36 plugs/eng gave us a hard time iodine always got it to let go. Of course back then we also used "milk of magnesia" on the threads before putting them back in. Now days I personally use modern chemistry, PB Blaster, Permatex anti seize, etc. I figure 21st century weasel piss has gotta be better than the old stuff, you know, that science thing
Cheers
Bob
Nova Scotia
Yamaha YT624EJ 24" 6hp
Made in Canada Yardworks 30" 31BE6B3H515 10.5hp Tecumseh 358cc HMSK105 Eng,
Honda FG110 Tiller, HHT35SU Trimmer, HT3813 Tractor
Ariens LM21SW Mower, Troy-Bilt CSV70 Shredder/Vac.
clamdigger is offline
Likes Grunt liked this post
post #8 of 14 Old 03-13-2017, 12:02 PM
Likes (Received): 45
I mixed a batch of that up once and thought it was too thick to do what t's supposed to do. I thought PB Blaster crept in better, especially if you applied some heat first.
dhazelton is offline
post #9 of 14 Old 03-13-2017, 12:42 PM
Thanks (Given): 231
Likes (Given): 2041
pulled from a "garage journal" thread
I saw this on another website....what do you think?
For all of you that are mechanically inclined..... Penetrating Oils Compared A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best! Here's the summary of the test results:
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix.............53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
Thanks Grunt, clamdigger thanked for this post
post #10 of 14 Old 03-13-2017, 01:01 PM
Thanks (Given): 171
Thanks (Received): 335
Likes (Given): 472
Likes (Received): 831
I've used Liquid Wrench, PB Blaster, ATF & acetone (mixed 50/50), and Kroil. None were magic, certainly. Now I typically use Kroil. In part because I can easily spray it, vs grabbing my old ATF & acetone, hoping it's still good, and brushing that on.
