Need some Help again!!!!!!!!!!! - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 08-26-2017, 03:14 AM Thread Starter
Thanks (Received): 379
Likes (Received): 1377
Question Need some Help again!!!!!!!!!!!
As you may or may not know I have a 1995 Buick Regal Grand Sport with the 3.8 liter V-6 Tuned port Injection. my question I am throwing out here is does that have the new R-134 Refrigerant/ freon or is that the old R-12. and if so can I use the new stuff with the old. or am I just plain screwed on this 1. so I am asking all the mechanics here who do this stuff day in and day oot. Because the AC is blowing a little to warm for my liking here
post #2 of 6 Old 08-26-2017, 05:35 AM
Likes (Received): 483
By mandatory law 94 and newer have R134a freon in their A/C systems (some started earlier). Yours being a 95 has R134a. I use an A/C machine at work, but they sell A/C "refill" kits at auto parts stores (look on YouTube, there may likely be instructions to refill the system).
YSHSfan is online now
Thanks POWERSHIFT93 thanked for this post
post #3 of 6 Old 08-26-2017, 09:42 AM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Should have a label under the hood telling you whats in there. You can also tell by the line connection ports,
R12 will have threads where your charging manifold / gauges connect and R134A will have no threads.
R134A connector looks like a smooth male protrusion with a groove around the top and a schrader / tire valve in the center.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is offline
post #4 of 6 Old 08-26-2017, 04:14 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4350
Likes (Received): 1734
Yours should be 134. They have a clip on fitting where the older R12 fittings were screw on.
The attached photo is for adapters to retrofit but the actual fittings sticking up should be identical to what you find on your AC lines under the hood.
They are two different sizes so you can't accidentally connect a refill kit to the high side and blow the can up in your hand
post #5 of 6 Old 08-26-2017, 05:27 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
Never....ever...ever... top-off or refill a system designed for R12 with r134 unless you perform a full flush (including the compressor to remove the Ester based oil), replace the accumulator, and pull a vacuum for at least 2 hours R12 and R134 don't play well together.
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #6 of 6 Old 08-27-2017, 09:38 PM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1027
Todd, from 94 on Buick used R134. You can put it in yourself. Watch a youtube vid. Get the refill kit. One can will be enough. Cool runnin'!
