furnace transfer switch for generator - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-10-2018, 04:43 PM Thread Starter
Thanks (Received): 173
Likes (Given): 411
Likes (Received): 661
any electrical brains out there ? ive been looking at a basic /easy to install transfer switch so i can easily run my furnace with my small generator. the issue is, the switch is rated for 1850 running watts and my generator is 3000 running watts. the furnace only pulls about 650 watts max .
will 3000 watts fry the switch ? i can only assume that the switch has electronics in it as the " switch" itself is basically a toggle/rocker type switch.
https://www.homedepot.com/p/Reliance...F151/202216476
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #2 of 18 Old 01-10-2018, 04:51 PM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
650 watts is probably just the burner, correct? Your furnace circuit is also running dampers if hot air, circulating pump(s). Is this a boiler or hot air furnace?
DriverRider is offline
post #3 of 18 Old 01-10-2018, 04:59 PM
The switch will only pull what is needed from the generator, it wont pump 3000 watts into the switch. I have a different brand switch that I installed myself, worked well powering my gas furnace on a test run with my ~2000 watt inverter generator.
Currently waiting for snow...
2004 Yard Machines 8/24 For the big storms
2003 Toro Powerlite That waits in my trunk, should the need arise... shoveling... HA!... ya, don't think so.
2002 Toro 2450 Primary machine
1991/1992 Honda HS621 Backup for the 2450
TheFanMan is offline
post #4 of 18 Old 01-10-2018, 05:11 PM
Likes (Received): 45
If your furnace is on a 15 (or 20) amp circuit now you could probably just get a 15 (or 20) amp transfer switch. You furnace will only draw what it draws regardless of generator output. You could always pick up the phone and ask these people.
https://www.electricgeneratorsdirect...iAAEgLXuPD_BwE
dhazelton is offline
post #5 of 18 Old 01-10-2018, 05:12 PM
Likes (Given): 28
The H-D switch is nice but all that is really needed is an electrical box, double pole ON-OFF-ON switch with cover plate and the wire.
post #6 of 18 Old 01-10-2018, 05:13 PM Thread Starter
Likes (Given): 411
its a combination oil/wood boiler, two seperate units, two pumps at 80w each running on the medium setting, the burner " looks like" it draws 6.5 amps ( no wattage shown), three zone valves and a few transformers for the wood side draft controls. its only a few years old and has the enerstar compliant tag on it. it seems like any problem would be on the generator side as the switch is rated for 1850 max running from gen, and im at 3000 running watts.......just cant figure out why the switch is rated for gen output and not circuit draw?
28 " Ariens Sno Tek
Toro CCR ss
post #7 of 18 Old 01-10-2018, 05:49 PM
Likes (Given): 28
1850 watts equates to 15A so if your circuit breaker for furnace currently in the fuse panel is 15A you good to go.
post #8 of 18 Old 01-10-2018, 06:07 PM Thread Starter
Likes (Given): 411
thats what i thought......still confused as to why the manufacturer rates that switch on gen output and not circuit draw.
28 " Ariens Sno Tek
Toro CCR ss
post #9 of 18 Old 01-10-2018, 06:30 PM Thread Starter
Likes (Given): 411
the box close to the furnace has a 20 amp fuse in it, was just hoping to put something in that was easy for the wife to deal with. she adapted to the plug n play world quite quickly for oldish people, ....so much more than a simple plug n play deal means an hour drive home from work and a return trip. lol
28 " Ariens Sno Tek
Toro CCR ss
post #10 of 18 Old 01-10-2018, 06:32 PM
Likes (Given): 28
Generators are rated by watts so it makes bundle/accessory shopping easier for the consumer.
