Wrenching GURU'S Needed Here Again!!!!!!!!! - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 05-12-2018, 01:19 PM Thread Starter
Likes (Received): 1383
Question Wrenching GURU'S Needed Here Again!!!!!!!!!
I found oot where the water deluge is coming from on the Heavy Chevy. turns oot GM uses a cheap foam gasket underneath the cowl area. where the air comes in 4 the HVAC system. my question is can I use that black gasket maker goo from Permatex or whoever makes that stuff. or is there something else/better oot there that I don't know about. so now all the Guru's that reside here can voice there opinions to the masses.
post #2 of 31 Old 05-12-2018, 01:31 PM
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 184
gasket maker goo
Hello Powershift,
I am not sure the goo would be safe to use due to the fumes from the gasket after it forms. That may be why they used a foam to seal it-assuming its a strip of foam material of course like they use on the window air conditioners to seal the upper glass pane from the outside air.
leonz is offline
post #3 of 31 Old 05-12-2018, 02:42 PM
Likes (Received): 30
Goop it up, do what you've got to do. Fumes go away quickly and you can think of it as a new car smell.
Only other choice is to take all that apart and replace the gasket. Not worth it in my opinion.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
Likes jrom liked this post
post #4 of 31 Old 05-12-2018, 04:07 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
How about using something a bit less aromatic like a silicone house caulk. 25 year warranty ??
post #5 of 31 Old 05-12-2018, 07:41 PM
Thanks (Given): 172
Thanks (Received): 70
Likes (Given): 1217
Likes (Received): 302
Are you sure that's where the leak is coming from? haven't had a windshield replaced recently have you? Water leaking in can be a real problem. I know it sucks to do, but if you plan on keeping it a while replacing the seal/foam tape gskt is the best answer.
gibbs296 is online now
post #6 of 31 Old 05-12-2018, 08:00 PM
Thanks (Given): 97
Likes (Given): 75
Likes (Received): 463
I'm a very good mechanic and I would not, it doesn't dry, it stays too gooey. You probably need something that sets up just a little but not too much. If it sets up into flexible bead, that's too much.
JLawrence08648 is offline
post #7 of 31 Old 05-13-2018, 08:17 AM
Thanks (Received): 125
Likes (Given): 43
Likes (Received): 904
2 cents here, maybe it's just your HVAC drain that's plugged and water is overflowing out the seem at the blower motor. Drains are known to plug up on those especially if you have a lot of critters and falling leaves and pine needles. You can either run a pipe cleaner up the drain or blow compressed air to clear the opening. If your unit has a cabin air filter sometimes you can get to the drain through the opening.
Coby7 is online now
post #8 of 31 Old 05-13-2018, 09:14 AM
Thanks (Given): 97
Likes (Given): 75
I agree completely. It's a drain hose that comes from the a.c. Coil inside the vehicle leading to the outside draining to the ground. If this hose gets clogged, with black yicky fungus, then the condensation, which is alot!, drains inside the vehicle on the floor.
The vehicles I've had I get under the car and poke a wire up the hose then watch the water flow! If you use an air compressor, it will clear it out but you are blowing the water inside the car.
post #9 of 31 Old 05-13-2018, 02:44 PM Thread Starter
Yeah I could use that Dynaflex. I think Dap makes that stuff??????
post #10 of 31 Old 05-13-2018, 03:08 PM Thread Starter
Underneath the black grill where the wipers attach to is where the intake is. I should have said that from the get go. I still will have to pull it off to run a bead of caulking around it. have to clean it all up anyway if I remember I will take some pics of this problem that is presenting itself unto me. so the masses here can see it all in living color.
