Another 1 of My Ponderings 4 The MASSES AT HAND. (Deck floor boards) - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-30-2018, 06:54 AM Thread Starter
Thanks (Received): 379
Likes (Received): 1377
Question Another 1 of My Ponderings 4 The MASSES AT HAND. (Deck floor boards)
Why in the Name of ZEUS do they use they use boards 4 deck floors. why not use plywood sheets or something along those lines 4 the deck floors. YES this is a oot side deck I am talking aboot. because I am going to have to something aboot mine. was oot blowing the leaves off of it. and my leg went right thru it. ended up on my TUCKUS. Because it would be cheaper to get sheets of wood. than those Deck boards if you ask me. Because I am not a gifted carpenter.
post #2 of 11 Old 10-30-2018, 08:02 AM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 928
Plywood sheets are far less suitable for outdoors than regular strips of pressure treated lumber..
Its much thinner, and will de-laminate easily outdoors..its really no good for an outside deck.
Most deck floors are made from 2x8's..quite thick and robust..
If yours broke through, your deck was either built with much thinner lumber than it should have been built with, or you waited far too long to replace rotting boards..
sscotsman is offline
Likes Grunt, z28lt1, detdrbuzzard liked this post
post #3 of 11 Old 10-30-2018, 08:25 AM
Thanks (Given): 72
Likes (Given): 182
Although I just learned, via google, there is "exterior plywood" that can be used:
https://www.hunker.com/13401518/what...-used-outdoors
Im not sure I would trust it to be weatherproof long term (like, a decade),
I would still prefer 2x8's..but I suppose it could be an option..
I see no good reason to use it though..lots of drawbacks.
post #4 of 11 Old 10-30-2018, 09:21 AM
RobertSX4's Avatar
Likes (Received): 8
wouldn't the plywood pool water and rot? I suppose you could cut it into strips but like Sscotsman said I wouldn't trust it over a 2x8
RobertSX4 is offline
post #5 of 11 Old 10-30-2018, 09:27 AM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1029
I've seen plywood deck floors. I would NEVER do it. Treated 2x6 or 2x8. Actually, now I'd probably install some type of composite deck material. It has certainly come a very long way from the old, original composite material. only thing is joists should be 12" OC instead of 16" .
post #6 of 11 Old 10-30-2018, 12:44 PM Thread Starter
Lightbulb
" HEY" OLD JOE!!!!!!!!!!!!! Next year sometime why Don't you Fancy a trip here to the PARADISE CITY. and help me replace the whole deck. I will cook you up 1 of those Roast Beef dinners I am Always posting here.
post #7 of 11 Old 10-30-2018, 12:47 PM Thread Starter
Yeah there are a few boards that need to be taken care of. just have not had the time to do it.
post #8 of 11 Old 10-30-2018, 12:50 PM Thread Starter
But what if you put the 4x8 sheets over the sticks??????????? Then just paint the SNOT oot of it all.
post #9 of 11 Old 10-31-2018, 09:15 AM
Thanks (Given): 172
Likes (Given): 450
I was just up there last month. Actually, my brother is asking if I might come back up soon. I'll let you know if you're really serious.
post #10 of 11 Old 10-31-2018, 09:17 AM
Thanks (Given): 172
Likes (Given): 450
Nope.
