Yellow Snow... - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-18-2019, 03:03 PM Thread Starter
Thanks (Given): 13
Thanks (Received): 19
Likes (Given): 50
Likes (Received): 124
Yellow Snow...
The other day I was clearing the EOD and I came across a patch of yellow snow behind the machine. I panicked a bit and immediately stopped the machine thinking maybe the drain plug had fallen off and the oil had drained out. I checked for leaks and there were none. I also checked the dipstick and it was down a tiny bit so I filled it to the full mark. The machine hasn't leaked at all since so my only conclusion is it was a neighbourhood dog that had left its mark, not the machine.
The moral of the story is: Watch out where you go and don't you eat that yellow snow...
Dannoman is offline
post #2 of 5 Old 02-18-2019, 04:08 PM
Thanks (Given): 31
Thanks (Received): 22
Likes (Given): 201
Ha Ha, that is funny unless its you that finds it. I use an old farm tractor at a property in the bush north of Huntsville Ontario. I few years ago, I came back to the cabin with it and stopped in the yard which has a generous portion of sand in the driveway. Just as I did the shutdown I noticed a circle, maybe 18" across, that was soaked and closer inspection showed there was actually yellow liquid puddled on the surface which quickly disappeared. After checking near by, I found some very fresh deer tracks in the sand, so someone else had been there to mark his/her spot. BTW, its wasn't right under the tractor.
contender is online now
post #3 of 5 Old 02-19-2019, 09:16 AM
Thanks (Received): 28
Likes (Received): 110
It could possibly be that your gear box might have a seal that is leaking. I would find trials of gear box oil every now and then prior to having mine rebuilt this past fall. I always new it was gear box oil because of the bad smell that the oil has.
Kielbasa is offline
Thanks zergarush thanked for this post
Likes zergarush liked this post
post #4 of 5 Old 02-27-2019, 04:01 AM
Even tour topic makes me smile, and I guess that what I think figured in the morale xDDD
zergarush is offline
post #5 of 5 Old 02-27-2019, 04:02 AM
when I read such topic names - it always makes me smile, but to be true I guessed what you mention in the end of the story xDDD
Similar Threads
Upgrading your snowblower lights to LED lights superedge88 General Snowblower Discussion 1364 02-23-2020 03:03 PM
Blowing in extreme cold grayhairedfreak Ariens Snowblowers 34 01-24-2019 12:56 PM
Ariens vs Honda (need some advice for my particular situation) bertbarndoor General Snowblower Discussion 72 10-31-2017 01:24 PM
snow thrower sickness/addiction leonz General Snowblower Discussion 4 10-06-2017 01:10 AM
Snowblowing Rules of Thumb SMFCPACFP General Snowblower Discussion 3 02-10-2012 08:57 AM
