New generator - never added gas - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 04-15-2019, 11:22 AM Thread Starter
Question New generator - never added gas
I bought a new portable gasoline generator last fall (2018). I assembled it, added oil, but never added gas.
Could sitting idle in my garage long-term with oil but no gas cause any problems?
There's a wrinkle, which is that the unit is a Generac EFI that needs to have its battery maintained, but I've got that covered.
https://www.costco.com/Generac-XT800...100408954.html
jakew8 is offline
post #2 of 5 Old 04-15-2019, 04:20 PM
Thanks (Given): 92
Thanks (Received): 66
Likes (Given): 406
Likes (Received): 209
I don't see any problems with leaving oil in it and never adding gas. You should be able to fire it up when you add gas without any problems since you have the EFi battery covered.
Honda HSS928AWD (upgraded chute, transmission)
Honda HS720AS (at sister's)
Honda EU2000i (generator)
Miles is online now
post #3 of 5 Old 04-15-2019, 06:55 PM
Thanks (Received): 42
Likes (Received): 182
I agree with Miles, no issue with letting it sit. The machine might sit on a warehouse shelf for a few years or even longer with no ill effects, except perhaps the battery. Adding oil won't change that.
The main reason they often ship without oil is so that it won't spill out if some yahoo doesn't know what "This side up" means.
WVguy is offline
post #4 of 5 Old 04-15-2019, 09:09 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
yup you should be ok. if it is not too hard of a job it would probably be better to disconnect 1 of the battery terminals just to make sure there is no ghost drain. i find doing so usually helps prolong a batteries life.
yardworks 31AH6WKF515
crazzywolfie is online now
post #5 of 5 Old 04-16-2019, 09:20 AM Thread Starter
Thanks all.
I have disconnected the EFI battery and I monitor its voltage with a multimeter. I also bought some long, flimsy jumper cables so I can jump it from a car if necessary.
Of course, the entire unit could end up being DOA due to a manufacturing defect or unseen shipping damage, so I have to just cross my fingers that it works once I gas it up!
jakew8 is offline
Similar Threads
Pic of LED Light Added to HS520 CalgaryPT Honda Snowblowers 8 01-10-2018 06:25 PM
added fuel shut off valve, wont stay running...... noupf General Snowblower Discussion 17 01-30-2017 11:24 PM
Can electric start be added to CCR Powerlite? Slinger Toro Snowblowers 5 11-23-2015 06:56 PM
Added some front weight to the new 1128 OXE Power Max HD today! ZippoMan Toro Snowblowers 12 02-24-2015 12:25 PM
Started new project & added 2 more machines HCBPH General Snowblower Discussion 6 08-29-2011 01:35 PM
