Worked on Kohler 724 ego - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 05-23-2019, 10:34 AM Thread Starter
Thanks (Given): 11
Thanks (Received): 22
Likes (Received): 52
Got my 1st taste of efi 724 v twin troubleshooting on 72” exmark laser mower with 4500 hours.
Symptoms were missing and backfiring after 15 minutes with blades on. Ok with blades off though. His mechanic wouldn’t work on it. I took a chance as opportunity to get a new landscapers $$. Very basic efi seems like kohler used off the shelf fuel injection from gm 3.1 v6 from early 90’s also seen similar on early Harley efi It was jump 2 pins and count the flashes of mil. No active codes present. Ended up removing sensors and homing them out. TPS sensor had bad spot in it where governor kept throttle with blades on under load which would be where tps spent most of its time at. After ordering the kohler part I realized that sensor was same delco sensor as gm 3.1
I’m not sold on efi yet but I do think that efi has contributed to a healthy 4500 Kohler engine. Motor seemed very tight and didn’t smoke. Probably less cylinder wash than a choked carb engine which has prolonged life.
groomerz is offline
Likes Grunt, micah68kj liked this post
Similar Threads
Kohler Command Pro engine question. bwdbrn1 SnowblowerForums Lounge 0 02-06-2016 10:07 AM
Kohler Magnum - winter oil weights? wildbill59 Snowblower Repairs and Maintenance Forum 12 01-06-2016 04:58 PM
Kohler K series? ChrisJ Re-Powering 8 03-28-2015 10:24 AM
