Water Proof Electrical Connectors. - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-21-2020, 08:11 AM Thread Starter
Thanks (Received): 379
Likes (Received): 1377
Question Water Proof Electrical Connectors.
I am Calling on the Masses at Hand. Because I am Searching 4 Waterproof Connectors. Looked at the corner hardware store, Home Depot and Menards but they just Don't Have what I want. Any places online that I do not know aboot.
post #2 of 9 Old 01-21-2020, 08:23 AM
Thanks (Received): 99
Likes (Given): 729
Likes (Received): 254
try https://www.delcity.net/ we get a lot of odd electric items from them for r[help when we restore a car
87powershiftx2 is offline
post #3 of 9 Old 01-21-2020, 08:25 AM
Coby7's Avatar
Thanks (Received): 123
Likes (Received): 873
I fine the Delphi work real good. I still add dielectric grease though to be safe.
https://www.ebay.ca/itm/Professional...kAAOSwYVlaO4Bx
Coby7 is online now
Likes classiccat, detdrbuzzard liked this post
post #4 of 9 Old 01-21-2020, 08:27 AM
JnC
JnC's Avatar
Thanks (Given): 69
Thanks (Received): 144
Likes (Received): 234
I have been using these ones for years without any issue, both for automotive and snowblower applications.
https://www.ebay.com/itm/Two-Pin-2-W...oAAOSwKhJdJxZC
prewired
https://www.ebay.com/itm/10Set-2-Pin...YAAOSw9mtd8HzH
they also have them in 3, 4, 5, 6 pins.
JnC is offline
post #5 of 9 Old 01-21-2020, 08:36 AM
oneacer's Avatar
Thanks (Received): 149
Likes (Received): 540
I am also a user of di-electric and I also use the heat shrink connectors, or heat shrink tubbing if need be.
My brother has also used FlexSeal Tape with good results as well.
oneacer is online now
post #6 of 9 Old 01-21-2020, 08:50 AM
oneacer's Avatar
Like these .
ID:	162879   Click image for larger version
ID:	162881   Click image for larger version
post #7 of 9 Old 01-21-2020, 09:59 AM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
Deutsch Connectors are good, used in automotive applications
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is offline
post #8 of 9 Old 01-21-2020, 07:22 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
I also use the Deutsch connectors..... I assembled a Master kit years ago, for the repair and installation on Truck and Off Road Equipment. I have the Deutsch Crimpers also. They are an OEM connector for many manufacture's. I stock 1 - 12 cavity connectors. They are also available for different wire gauge sizes. They are heavily supported. They hold up well when used as lighting connectors on Highway plows and Sanders....pretty hostile environment.
GLuck, Jay
JayzAuto1 is offline
Likes Grunt, toromike, classiccat liked this post
post #9 of 9 Old 01-22-2020, 06:12 AM
Likes (Given): 729
di-electric grease is a most even in dry areas as it helps stop corroding of the terminals inside the connector. butt connectors i personally like the solder seal type https://www.delcity.net/store/Heat-S...05408.h_824682 when heated the silver solder melts ,seems to do a job like having soldered and applied heat shrink tubing in one shot
