Keeping That Little Red Straw With The Spray Can - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 04-12-2015, 04:07 PM Thread Starter
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
I just had one of those eureka moments (no, I didn't cut the cheese) I was tinkering out in the shop and finishing the final items on my spring snowblower maintenance routine. I have a lot of different aerosols with the little red straw, but once you take it off of the can the first time, good luck keeping it with the can after that. I happened to notice a roll of Velcro plant ties that my wife uses when she stakes up tomato plants and the like. A light came on in my head . I cut off 6 inches or so, wrapped it tight around the can and it holds the straw better that anything else I've tried. Tape gets gooey, rubber bands get soft and kind of melt and twist ties aren't real good either. This works great.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
Likes Grunt, RAYAR liked this post
post #2 of 20 Old 04-12-2015, 04:09 PM Thread Starter
Likes (Given): 266
I couldn't get it to post two pictures at once, so here's what it looks like in use.
Larry
post #3 of 20 Old 04-12-2015, 05:25 PM
Thanks (Given): 589
Likes (Given): 4358
Likes (Received): 1739
Or just use a common rubber band. I like the thick ones that come on the broccoli from the grocery store.
Likes Bob E liked this post
post #4 of 20 Old 04-12-2015, 06:37 PM
Thanks (Given): 173
Likes (Given): 455
Likes (Received): 1030
Both good ideas. That velcro seems to be the ticket.
Thanks fellas!
Likes Blue Hill liked this post
post #5 of 20 Old 04-12-2015, 07:56 PM Thread Starter
Likes (Given): 266
Thanks K4, but if that means I have to start eating broccolies, I'll stick with my Velcro
Larry
post #6 of 20 Old 04-12-2015, 08:51 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3335
Likes (Received): 679
I have had excellent results using old bicycle inner tubes cut into 3/8" wide strips. I tie the ends together so the band is about half the size of the object I'm wrapping around. I made a large band to hold the plastic bag in the kitchen garbage can, and over two years later, it is still as stretchy as when it was new.
Thanks Blue Hill thanked for this post
post #7 of 20 Old 04-13-2015, 12:25 PM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
I've noticed that some of the newer aerosols have a new style spray tip where you never remove the red hose, it flips down if you want to use it on regular spay, then back up and into place for jobs the require the hose.
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #8 of 20 Old 04-13-2015, 01:37 PM
Likes (Received): 1379
IT would appear that you have a slight disregard for house keeping there BROTHER LARRY.
Likes Grunt liked this post
post #9 of 20 Old 04-13-2015, 02:51 PM Thread Starter
Likes (Given): 266
I was afraid somebody would notice that.
Larry
post #10 of 20 Old 04-14-2015, 07:58 AM
Thanks (Received): 238
Likes (Received): 608
But he probably knows right were everything is, and if you moved it, he couldn't find it.
