Being that I am lazy… - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-03-2012, 01:55 PM Thread Starter
abumpa's Avatar
One thing I have always hated is shaking paint cans. Consequently, I usually don’t shake them enough so I built a powered shaker to do the work.
The shaker is made from a vertical shaft B&S engine off of a push mower. The owner of the mower hit a steel pipe sticking up and bent the crankshaft. He got a new mower and I got the junk.
I mounted the engine sideways on a wood platform and installed a pulley where the flywheel goes. Removed the head and mounted the can holder to the piston. I removed the oil ring from the piston but left the compression rings in. It is powered by a 1/6 HP electric motor at 1725 RPMs.
Being that the vertical engine is now mounted horizontal I still need to seal the crank case holes and make an oil slinger at the bottom of the rod. For now I just hand oil the moving parts.
Here is a photo and video…
Below is a link to a video of the shaker working.
http://youtu.be/_uEih4vJbk4
abumpa is offline
post #2 of 10 Old 01-03-2012, 02:00 PM
Awesome. It might work better if you put the paint can upside down.
post #3 of 10 Old 01-03-2012, 02:17 PM Thread Starter
abumpa's Avatar
There is a small nut sticking up under the can that holds the bottom plate to the rod in the piston. Being that all aerosol cans have a concave bottom that clears the nut, (at least all the paint can I have do) I figured this would not be a problem. In order to turn the can over I would have to mount the lower plate differently.
Seems to work good though as it is. The can in the shaker has been sitting around for at least 12 years. I usually have to throw away old paint cans but 5 minutes in the shaker and this one worked great.
abumpa is offline
post #4 of 10 Old 01-03-2012, 02:21 PM
Great then.
post #5 of 10 Old 01-03-2012, 06:36 PM
Thanks (Received): 234
Ya' know, there's all kinds of thoughts come to mind, but I guess innovative fits best.
post #6 of 10 Old 01-04-2012, 07:51 AM
Very ingenious to say the least! I have an old engine around here that I might rig up like that now that you have given me the idea. Recently I was doing a bit of rattlecan painting and most of the Rustoleum that I was using says to shake it for at least one minute.
Thanks for the idea!
Wayne
Wayne195 is offline
post #7 of 10 Old 01-05-2012, 02:21 PM
Shacking spary cans SUCK!!! Awesome idea
Snowmann2011 is offline
post #8 of 10 Old 01-06-2012, 12:01 PM
Thanks (Received): 137
Likes (Given): 14
Likes (Received): 322
Paint Shaker
Now that's thinking "Outside the box". Very novel ideal. I saw another one a while back, also unconventional. Replacement arm for a reciprocating saw. You put this adapter on in place of a blade and strap your can in and shake the heck out of it. Don't know anything else about it.
HCBPH is offline
post #9 of 10 Old 01-06-2012, 04:23 PM Thread Starter
abumpa's Avatar
Thanks for the comments guys and I have already made some changes. I liked the suggestion from Shryp about turning the can over. While I couldn’t do that I did ad some structure to the platform at a 90-degree angle at the shaker end. I can now turn the whole thing on end (electric motor up) and shake the can horizontally as well as vertically.
I also cut off the bent portion of the crankshaft closer to the case.
Forgot to mention total cost was $1.49 for the whole project. I was given the bad B&S engine and had everything else on hand except 2 foot of threaded rod for the can holder.
abumpa is offline
post #10 of 10 Old 01-07-2012, 01:16 AM
Location: In the land of slush on the shores of Long Island Sound in CT
That's just great and thanks for the video too. Without your resources I'm stuck with a purchased solution.
MixKwik - The Premiere Aerosol Can Mixer and Paint Shaker
Marcintosh is offline
