1979 Craftsman Drift Buster - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-27-2017, 08:03 PM Thread Starter
Hello, I am new to this forum, I recently bought a (see above). The auger bearing was blown, well I am trying to get the auger pulley off the shaft? Well I messed that up pretty bad. Unless someone can help me find a new one I guess I will part it out. Everything is great on it, but I cant figure out how to get that pulley off? Any ideas? Tried heat, pulley puller, soaking it with WD40 rust penetrate? The pulley now looks like a mushroom and the part number I have is out dated. I do have the owners manual for it, but that is no help at this point?
bumblebills is offline
post #2 of 5 Old 03-27-2017, 08:09 PM
Thanks (Given): 13
Thanks (Received): 124
Likes (Given): 145
Likes (Received): 286
A cut off wheel on a angle grinder works great, Ask me how I know LOL
Dauntae is online now
post #3 of 5 Old 03-27-2017, 09:34 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
This is where a OXY ACET torch is necessary.
post #4 of 5 Old 03-28-2017, 05:07 PM
Likes (Received): 20
There is a good chance I can help. PM your needs/pn's if you have them.
sidegrinder is offline
post #5 of 5 Old 03-28-2017, 11:55 PM
Thanks (Received): 112
Likes (Received): 296
Sounds like the cutoff wheel is the way to go. cut the pulley straight across as close as possible to the hub, then cut the hub, slot from the cutoff wheel should loosen up the grip. careful not to go thru to the auger shaft and cut the side opposite the woodruff key if there is one.
Work fascinates me.
skutflut is offline
