Ariens 03710000 Chute Crank - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-20-2019, 08:46 PM Thread Starter
Likes (Received): 11
While working on my motor swap on my '71 Ariens, I knew I would need a new chute crank and now I have a part number! So far the cheapest I have found them is around $60 and it was a local pickup only. Anyone have one or something similar they would be willing to part with? It does need to fit the worm gear (which I still have). Not sure if I want to get it right now, can't do much till warmer weather anyway, but just getting feelers out there if anyone has one.
Part number 03710000
Stock image for reference only.
Cujoe_da_man is offline
post #2 of 8 Old 02-20-2019, 09:10 PM
Jackmels's Avatar
Thanks (Received): 192
Likes (Given): 451
Likes (Received): 792
That photo is for a 924 series. 71 ariens did not have u- joints, it has a straight shaft and crank with an eye-bolt to attach to the handlebar. I have used available, PM if interested.
Jackmels is online now
post #3 of 8 Old 02-20-2019, 09:57 PM Thread Starter
Yes, I need the one pictured for my motor swap so I can clear the new engine
post #4 of 8 Old 02-20-2019, 10:22 PM
Jackmels's Avatar
Likes (Given): 451
That won't work. The 924 gear angle is different than the 10000 series. You need to cut the original shaft, and add u-joints. Here's one of mine I did.
post #5 of 8 Old 02-20-2019, 10:32 PM Thread Starter
Yep, that's exactly what I'm looking to do, I forgot I need to adapt my worm gear to the shaft, but that's easy enough to do, it's finding the universals that's the problem
post #6 of 8 Old 02-21-2019, 07:26 AM
Thanks (Given): 77
Thanks (Received): 161
Likes (Given): 398
Likes (Received): 637
3/8 drive socket universals work well, but require some welding.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #7 of 8 Old 02-21-2019, 08:58 AM
Thanks (Given): 11
Thanks (Received): 108
Likes (Given): 19
Likes (Received): 301
Most of the Ariens gears I've seen are held on to the shaft with roll pins. You might be able to just drive the pins out and swap your old gear onto a new shaft with a universal, and avoid having to do any welding.
ELaw is offline
post #8 of 8 Old 02-21-2019, 09:13 AM
Jackmels's Avatar
Likes (Given): 451
I can supply you with a parts kit of 2 u joints, a support bracket, and a length of rod to duplicate the system shown in my photo. No Welding. You'll need to cut the rod behind the original worm gear, and drill small holes through the shaft to secure the u joints where you want them. PM if interested in the kit.
Similar Threads
Honda Snowblower High Chute Crank and Tall Handlebar Kits - (Truckee, CA) E350 Honda Snowblowers 4 08-31-2019 11:31 PM
Honda Snowblower High Chute Crank and Tall handlebar Kits alpinebobl Snowblowers and Snowblower Parts for Sale 7 01-21-2019 11:54 PM
Ariens ST1032 Restoration jpswift1 Ariens Snowblowers 44 01-25-2016 11:01 PM
Ariens Deluxe 28 SHO 921044 Squeaky Chute Control Elt31987 Snowblower Repairs and Maintenance Forum 3 10-08-2015 08:28 PM
Considering buying an Ariens. Chute control and Auto-Turn seem problematic. pwm Ariens Snowblowers 16 10-27-2014 02:22 PM
