TORO 8/32 part needed - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 05-03-2014, 09:40 PM Thread Starter
Likes (Received): 8
I am in need of an impeller for a Toro 832 snowblower. Let me know what you have available.
Thanks Jerry....
JerryD is offline
post #2 of 8 Old 05-04-2014, 01:57 PM
Thanks (Received): 372
Likes (Received): 1318
Thumbs up
Thanks Jerry....
I will have to make some calls. but it will not be cheap!!!!! what is wrong with it????????????
post #3 of 8 Old 05-04-2014, 02:08 PM Thread Starter
Likes (Received): 8
Now that I have it apart, someone had changed the one of the shear bolts with a stainless bolt that didn't shear and it looks like the impeller digested a brick at one point. The back of the impeller has been rubbing so long that in one place (at a blade mounting point) it is paper thin. I could put hours in to it trying to repair it or find a decent used impeller and take the hit.
JerryD is offline
post #4 of 8 Old 05-04-2014, 02:20 PM
TORO does not use those sheer pins only grade 5 or stainless steel bolts. the impeller bearing and the bent impeller threw it out of phase. which caused the wear.. I had the same issue with mine. I will make a call Monday and PM YOU WITH THE FINDINGS.: eek:
post #5 of 8 Old 05-04-2014, 02:29 PM Thread Starter
Likes (Received): 8
Good deal, Thanks.
JerryD is offline
post #6 of 8 Old 05-26-2014, 11:31 AM Thread Starter
Likes (Received): 8
The replacement impeller has been located, procured, and installed. Thanks go to "Powershift93" for the help in locating it.
Jerry...
JerryD is offline
post #7 of 8 Old 05-26-2014, 11:36 AM
Thanks (Given): 559
Thanks (Received): 736
Likes (Given): 4174
Likes (Received): 1606
Jerry, you should toss up some photos of the damaged one. It's always interesting to see what people run across.
post #8 of 8 Old 05-26-2014, 08:11 PM
Jerry...
ANYTIME there Jerry, ANYTIME.
