Ariens Sno Thro 10995 (910995) parts needed: shift lever bracket, shift rods, etc. - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 02-06-2016, 05:28 PM Thread Starter
Thanks for looking.
You can send me a pm or email me @ [email protected]
  • upper shift rod (part #10235)
  • lower shift rod (part #10228)
  • bottom cover (part #10147)
Parts below are from and around the friction disc assembly:
  • shift lever bracket (part #10215)
  • idler arm hub spacer (part #10240)
  • bracket pin (part #10212)
  • sprocket (part #10276)
  • fork shaft (part #10368)
I borrowed this pic from a member on the forum. Both the spacer and bracket attach or bolt to the right side of the housing. You can also see how the shift rod enters through the rear of housing which is at the top of the pic on the right. The rod then attaches to the shift lever and then attaches to the bracket I'm looking for.
rmchevelle is offline
