Ariens ST824 auger/gear/fan unit wanted - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-18-2016, 05:47 PM Thread Starter
Likes (Received): 6
Let me know if you have one and how much. Near VA will be great.
ST824 model 924082.
bcjm is offline
post #2 of 14 Old 02-18-2016, 06:14 PM
Thanks (Given): 167
Thanks (Received): 301
Likes (Given): 411
Likes (Received): 1000
Call me ignorant but what's a "fan unit" ? Are you ISO an impeller?
post #3 of 14 Old 02-18-2016, 07:33 PM
Thanks (Given): 560
Thanks (Received): 736
Likes (Given): 4179
Likes (Received): 1606
Yup, auger, gear and impeller. Have you tried Ebay yet ??
Did you need the actual augers too or just the shaft ??
post #4 of 14 Old 02-18-2016, 09:42 PM Thread Starter
Likes (Received): 6
I would like to buy the whole thing including the augers, gear and impeller.
bcjm is offline
post #5 of 14 Old 02-19-2016, 12:55 AM
AriensProMike's Avatar
Thanks (Received): 18
Likes (Received): 55
You might be able to get a whole machine on your local craigslist for the price it would cost. Also recover your money with the balance of the parts you have left. Sometimes you get lucky and find one with a blown motor on the cheap.
AriensProMike is online now
post #6 of 14 Old 02-19-2016, 05:45 AM
Likes (Received): 42
Unfortunately, the gear box is the weak link on this model. The remainder of the unit is a Sherman tank. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #7 of 14 Old 02-19-2016, 12:56 PM Thread Starter
Likes (Received): 6
My augers and shear pins are rusted on the shaft. The auger gear is leaking. I know I am not going to be able to remove them without any damage. I am just planning the worst. If I can find a whole thing that will be the best. Really don't want to mess with the gears.
If I can find the same machine locally that will be great too. So far no luck.
bcjm is offline
post #8 of 14 Old 02-19-2016, 08:17 PM
The ideal solution is to get those augers removed so your shear pins will work. If you need to use the machine before you get it fixed you could refill the gearcase with '00' grease instead of gear oil. The grease is thicker than gear oil but thinner than actual chassis grease so it should lube things up well without running out. That is what a lot of the "sealed" units use as well as some lawn tractor transmissions.
post #9 of 14 Old 02-19-2016, 08:22 PM Thread Starter
Likes (Received): 6
I tried. I know I am not going to be able to removed the auger and sheer pins without damage. I dont need to use this machine this winter. I just like to fix it.
bcjm is offline
post #10 of 14 Old 06-04-2016, 09:41 PM
evh
evh's Avatar
Likes (Given): 57
Likes (Received): 17
Let me know if you are still looking for parts for the ST824. I may have some.
evh is online now
