ARMORskids Road Test - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-03-2019, 12:16 AM Thread Starter
SnowH8ter's Avatar
Thanks (Received): 15
Likes (Given): 18
Likes (Received): 51
Finally had a chance to road test the ARMORskids that I received from Bob in Jan. We got whacked pretty good with the white stuff and I really didnít want to go out and play because the air temp was -25C and the wind chill value was bouncing around -35. Needless to say, bit the bullet and out I went. I installed the skids using the Huskyís optional poly skids (unmodified) as spacers and with the runner portion of the ARMORskids facing in. This config is depicted at the bottom of this page on Bobís site:
Husqvarna ST330P | Snow Blower Skids
The shave plate has about 3/8 inch clearance, which is more than the 1/8 to 1/4 inch I typically run with. Iíd need to shave some off the poly shoes to get the shave plate closer to the ground. Nevertheless, 3/8 inch was going to be just fine for a road test. And fine it was! Maneuvering the big Husky around with the ARMORskids installed was considerably easier than with the OE metal skids Ė no hang ups whatsoever. Asphalt and turf, the Huskyís steering comes alive and is so much more responsive with the new shoes. I like em! I had to quit liking them after about an hour though cuz I was turning into a popsicle!
Wounded 30-inch Mastercraft (MTD) circa 96
17 ST330P Husky
SnowH8ter is offline
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
Thanks detdrbuzzard thanked for this post
Likes knu2xs, Grunt, aldfam4, michaelnel liked this post
post #2 of 10 Old 02-03-2019, 06:13 AM
Thanks (Given): 139
Thanks (Received): 270
Likes (Given): 372
Likes (Received): 912
Iv'e always heard good things about Armor Skids.
micah68kj is offline
post #3 of 10 Old 02-03-2019, 07:29 AM
aldfam4's Avatar
Thanks (Given): 201
Thanks (Received): 40
Likes (Given): 568
Likes (Received): 109
In addition, if you have any cracks or bumps or heaved sidewalks, these skids glide over them and save your bucket and to a lesser extent your scrapper bar!
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #4 of 10 Old 02-03-2019, 10:35 AM
vmax29's Avatar
Thanks (Given): 17
Likes (Received): 82
They also save your back and avoid the full stop gut punch from the handlebar when you are moving along at a brisk pace and hit those bad sidewalk seams. I know some of you out there must have experienced this.
vmax29 is offline
Likes aldfam4, gibbs296 liked this post
post #5 of 10 Old 02-03-2019, 11:20 AM
Likes (Given): 1645
Likes (Received): 581
I had armor skids on my 826 toro ( sold ) and loved them, I also have them on both of my 521's
post #6 of 10 Old 02-23-2019, 12:01 AM Thread Starter
SnowH8ter's Avatar
Likes (Given): 18
The Trade-off
2nd road test and had to contend with some piles of packed snow. Piles had been accumulating over a three week period. Unsurprisingly, the ARMORskids tend to ski up the packed stuff at the bottom of the pile making it tougher to dig in as easily as with the OE metal skids. I'd originally installed the ARMORskids with the wide tip fwd so I flipped the skids to present the skinny tip to the pointy end. I didn't make much of a difference. I'm not too worried about it. An acceptable trade-off for the otherwise improved maneuverability and the way these things work in fresh snow.
17 ST330P Husky
Likes aldfam4 liked this post
post #7 of 10 Old 02-23-2019, 06:43 AM
Homesteader's Avatar
Likes (Received): 33
Front bucket riding up on. EOD is a common problem with wheeled machines.
Do you have a front weight kit? This helped me on my older Ariens - not sure if it’s something Husqvarna offers OEM but you could always use flat bar steel and a drill.
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
post #8 of 10 Old 02-23-2019, 07:49 AM
aldfam4's Avatar
Thanks (Given): 201
Likes (Given): 568
None better IMHO.
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #9 of 10 Old 02-23-2019, 07:57 AM
aldfam4's Avatar
Thanks (Given): 201
Likes (Given): 568
I have the ARMORskids on my Ariens 924086 below, I just added 20lbs to the top of the bucket for EOD snow, they are removable and transferrable to my Craftsman.
Name:	snow blower weights3.JPG
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #10 of 10 Old 02-23-2019, 09:49 AM
northframingham's Avatar
Thanks (Given): 29
Likes (Given): 53
I put the thicker version of ArmorSkids and (2) 10# weight kits on my Ariens HydroPro 28"
In my opinion they both should come stock on snowblowers!
2015 Ariens Hydro Pro 28" w/ B&S 420cc
w/(2) 10# weight kits and ArmorSkids
2012 Snapper SS822E 22" w/ B&S 205cc
northframingham is offline
You may not post new threads
You may not post replies
