New design of Skids - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 02-18-2016, 06:26 PM Thread Starter
Hanky's Avatar
Thanks (Given): 90
Thanks (Received): 72
Likes (Given): 307
Likes (Received): 139
New design of Skids
Received my new set of ARMORskids this afternoon, they are great it looks like the new design is going to be a winner for sure. With two different tips on each skid. I can see where these will work really really well with the EOD snow as machine will not want to ride up. As well in my case where the heavy snow comes of the garage roof and lands on my deck. A very well built product, and super happy that Bob has redsigned his Skids to what is a far better product.
This is my heavy snow that comes off my garage roof on the other side on my deck.
Hanky is online now
Thanks 69ariens thanked for this post
post #2 of 27 Old 02-18-2016, 06:56 PM
Thanks (Received): 33
Likes (Received): 54
The fit and finish is awesome on Bob's product. The A2D - attention to detail is consistent, even with his spacers !
mobiledynamics is offline
post #3 of 27 Old 02-18-2016, 07:05 PM
Thanks (Received): 157
Likes (Given): 359
Likes (Received): 593
very nice skids ! now i have ask.....how did you manage to get that pic of the snow sliding off the roof !!!
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 27 Old 02-18-2016, 07:05 PM
Cardo111's Avatar
Thanks (Received): 124
Likes (Given): 78
Likes (Received): 167
Nice new skid shoes! That narrow end looks like it will cut right threw the plow pile without riding up. Good luck with them.
Cardo111 is offline
post #5 of 27 Old 02-18-2016, 07:20 PM
knu2xs's Avatar
Thanks (Given): 123
Thanks (Received): 117
Likes (Given): 257
Likes (Received): 138
I think you'll like that new design. I've been using them for most of the season and while I have yet to put them to the "heavy duty" drift test, they have shown a lot of promise on the drifted, packed, snow that I have used them on.
Time to gather a little more data. I have to go out and do a light drift cleanup in a few minutes, before the temp rises and the rain starts.
knu2xs is offline
post #6 of 27 Old 02-18-2016, 07:34 PM
Thanks (Given): 94
Likes (Given): 219
Likes (Received): 134
Interesting to see the dual tip design. What's the thought process/strategy on which direction to install?
uberT is offline
post #7 of 27 Old 02-18-2016, 07:50 PM Thread Starter
Hanky's Avatar
Thanks (Given): 90
Likes (Given): 307
I was out talking to the neighbor when we heard the slide starting it moves quite slow so I snapped a few pictures and waited till the other side finished then the hard work started, till I had enough room for the Toro. Had to brake out the shovel for a bit and it was hard work.
Hanky is online now
Thanks nwcove thanked for this post
Likes nwcove liked this post
post #8 of 27 Old 02-18-2016, 08:10 PM
I've only used mine once, with the narrow tip end.
The bottoms of mine are lined with poly though.
With the poly lined bottom on the garage floor, I can effortlessly slide the bucket left and right with ease.
I don't know how much the poly plays on surface tension ontop of snow vesus no poly and the weight just eating into it, but when attacking the EOD, mine did ride up here and there and I had to take a couple of reverse-forward passes to munch all the way down.
post #9 of 27 Old 02-18-2016, 08:19 PM
knu2xs's Avatar
Thanks (Given): 123
Likes (Given): 257
If you were generally dealing with areas where drifting isn't an issue then you could mount the wide profile forward, but I think either way would work.
If drifts are something you expect in your future, which is my case, the narrow end should be mounted forward in order to cut into drifts.
Here they are mounted thin end forward. The profile looks a little dirty because I picked up some dirt "edge jumping" the side of our driveway.
knu2xs is offline
post #10 of 27 Old 02-19-2016, 07:41 AM
Knu -
I spy SS hardware on your shoes.
How long have you had them on...
I have seem (more often than I would prefer) what happens when SS galls on steel, aluminum and it's not fun. Debated on swapping hardware to SS but decided not to, bearing my experience in seeing what happens when ss galls.
Worst thing I would want is to loosen the nuts one day, only to find the SS bolt seized onto the bucket
You may not post new threads
You may not post replies
