824 impeller bearing - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-02-2017, 10:42 PM Thread Starter
Hi all,
First time posting on this forum. I had and 824 with a bad motor. I replaced the motor and after a few test runs with the auger engaged, I found that the impeller bearing is a little sloppy. I have 0 experience with TORO brand. I'm more familiar with he Ariens and John Deere. After looking over the machine, it appears that it is not a small project. I'm thinking i need to remove the entire auger/impeller parts to get the machine split. I could just wing it and go as I see fit. However if there is a repair manual or procedure to follow, I would like to go that route. Mod # is 38080 and see # is 6003240.
Any help would be appreciated.
Randy
rkchainsaw is offline
post #2 of 13 Old 01-03-2017, 10:10 AM
Thanks (Received): 353
Likes (Received): 1163
Originally Posted by rkchainsaw View Post
Hi all,
Randy
You are going to have to kick it old school. split it in half. and start taking it apart. you can always PM for help if you need it.
post #3 of 13 Old 01-03-2017, 03:53 PM Thread Starter
Ok, got it all apart and found a bad bearing. Wasn't as bad as I was thinking.
Getting ready to order parts.
Randy
post #4 of 13 Old 01-03-2017, 04:15 PM
Likes (Received): 277
Glad to hear you weren't having a bad time with seized/stuck shafts! Be sure to lube everything liberally with grease when she goes back together and you will save yourself future grief......
post #5 of 13 Old 01-03-2017, 09:54 PM Thread Starter
Thanks, I will definitely "never seize " it back together.
post #6 of 13 Old 01-03-2017, 10:17 PM
Likes (Received): 8
I did an impeller bearing replacement on my Toro 832 a couple years ago. I couldn't budge the bearing. I made a puller to hold the bearing in place and push the shaft out of the bearing along with a bunch of heat. I posted some pics of the bearing and the puller in the gallery Snowblower Forum : Snow Blower Forums - JerryD's Album: 1971 832 Toro - Picture
I hope it helps.
Jerry...
JerryD is offline
post #7 of 13 Old 01-03-2017, 10:58 PM
I just did my impeller bearing, I used a propane torch to heat up the pulley, it almost lifted off after some heat.
1988 Toro 824 Powershift
1994 John Deere TRS-21
fibersport is offline
post #8 of 13 Old 01-04-2017, 08:34 AM Thread Starter
Jerry and fibersport,
Those were the scenarios that i was expecting, however, this darn thing popped right off with only a couple sprays of WD40 and some love taps with a hammer. Simply amazing!!!!! One thing I have to say that the machine is exceptionally clean and free of rust for its age. I'm thinking its a 1986 model. Ordered the parts last night and will hopefully slide it back together real soon. Thanks again for all the tips. I received a helpful message from another fella about the manuals. I can't seem to find it so I have to do some digging. I'm new to this website so it may take a bit to find my way around. These sites are great.
Randy
post #9 of 13 Old 01-04-2017, 11:11 AM
Thanks (Received): 36
Likes (Given): 57
Likes (Received): 84
GMorning rk, Try this website, https://www.toro.com/torodealer-gene...KGwaAopZ8P8HAQ. That will take you to the Toror website and allow you to D/L the manuals you need, once you enter the model number. I believe there is a 'sticky' on the Toro forum for drivetrain service. GLuck, Jay
JayzAuto1 is online now
post #10 of 13 Old 01-04-2017, 12:34 PM
Impressive little puller there!
