724 auger turns when not engaged - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 08-23-2017, 12:37 PM Thread Starter
Just replaced both belts and adjusted tension as loose as possible but the auger still turns when not
engaged. Any help would be appreciated
Bill
tdbiwmw is offline
post #2 of 10 Old 08-23-2017, 12:58 PM
Likes (Received): 302
What
post #3 of 10 Old 08-23-2017, 01:56 PM
Jackmels's Avatar
Thanks (Given): 108
Thanks (Received): 164
Likes (Given): 347
Likes (Received): 650
Could be the wrong Belt. Did You Use OEM Belts?
Jackmels is online now
post #4 of 10 Old 08-23-2017, 04:53 PM
Thanks (Given): 485
Thanks (Received): 354
Likes (Received): 1170
Thumbs up
You are going to have to adjust the rod backward for the new belt. because the new belt hopefully the right 1. and not a auto belt. is going to ride higher in the pulley groove being brand new. let me know the score on that 1. you can PM Me for my E-MAIL if need be.
post #5 of 10 Old 08-23-2017, 06:50 PM Thread Starter
model 38072
tdbiwmw is offline
post #6 of 10 Old 08-23-2017, 06:51 PM Thread Starter
mdel 38072
tdbiwmw is offline
post #7 of 10 Old 08-23-2017, 06:58 PM Thread Starter
model 38072
tdbiwmw is offline
post #8 of 10 Old 08-23-2017, 09:37 PM
orangputeh's Avatar
Thanks (Given): 694
Thanks (Received): 186
Likes (Given): 1113
Likes (Received): 1119
can you post a pick of the belt on the machine?
"It Feels Like Beer O'Clock "
orangputeh is online now
post #9 of 10 Old 08-23-2017, 09:46 PM
Thanks (Given): 89
Thanks (Received): 180
Likes (Given): 69
Likes (Received): 409
Not all belts are the size they claim. Look up the size in inches the manufacturer recommends, then remove the belt and measure the outside with a flexible tape using paper clip clamps for a tight and exact fit.
JLawrence08648 is offline
post #10 of 10 Old 08-23-2017, 10:17 PM
Mak
