26-6370 Drive Shaft Spacer 1984 524 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 10-27-2017, 02:21 PM Thread Starter
So the 26-6370 drive shaft spacer is and has been no longer available. What does one do about this?
I'm sure this is what I needed last year when I was playing around with the 524. It does have a nice new friction wheel and belts now but that wasn't the fix.
eshernius is offline
post #2 of 6 Old 10-27-2017, 04:10 PM
Likes (Received): 302
I wat
post #3 of 6 Old 10-27-2017, 04:26 PM
Thanks (Received): 28
Likes (Received): 41
They are 1 1/4 outside, 7/8 inside, and about 11/32 thick. You will have to make one or look for someone with old stock.
351beno is offline
post #4 of 6 Old 10-27-2017, 10:56 PM Thread Starter
any idea of what this spacer actually does? After watching a video I have i'm thinking the bearing might be worn away. Does anyone know how thick the bearing should be?
post #5 of 6 Old 10-28-2017, 12:09 PM
The rear bearing 20-1730 looks worn it should be 3/4 thick from the rear to where it hit the washer that's before the plate.
351beno is offline
post #6 of 6 Old 10-28-2017, 12:18 PM Thread Starter
going to pick up a new bearing and see where that goes.
