1971 Toro 832 Auger gearbox lube? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-26-2014, 09:46 PM Thread Starter
Likes (Received): 8
I recently picked up a rather nice 1971 Toro 832. I figured I better do some maintenance to it. Can anyone tell me what Toro recommended for lube in the auger gearbox?
Thanks,
Jerry...
JerryD is offline
post #2 of 10 Old 01-26-2014, 11:14 PM
Likes (Received): 42
Hi Jerry,
Can't find a specific answer in my search...I'm sure you'll be fine with a 90 weight "gear oil." You should be able to get it at any auto parts place. The important thing is don't overfill her. She'll get too hot. MH
motorhead64 is offline
post #3 of 10 Old 01-27-2014, 12:35 AM Thread Starter
Likes (Received): 8
Thanks for the info, I'll give it a shot.
JerryD is offline
post #4 of 10 Old 01-27-2014, 04:40 AM
Likes (Given): 1645
Likes (Received): 581
its more likely that it uses lubriplate mag 1 grease
napa equivilant napa sta=lube pnsl-3144
post #5 of 10 Old 01-27-2014, 11:13 AM
Thanks (Received): 349
Likes (Received): 1145
USE 80-90 WEIGHT GEAR OIL. NON SYNTHEIC. THE SEALS WILL NOT HOLD THE SYNTHEIC STUFF
post #6 of 10 Old 01-27-2014, 11:30 AM Thread Starter
Likes (Received): 8
If it helps, the gearbox is a pretty heavy, cast iron unit.
JerryD is offline
post #7 of 10 Old 01-27-2014, 11:37 AM
does not matter how heavy the gear box is. use 80-90 weight non synthetic gear oil. I have a 1974 toro 8-26.
post #8 of 10 Old 01-28-2014, 09:07 AM Thread Starter
Likes (Received): 8
I mentioned the construction of the gearbox in an effort to help you identify the unit. I have topped it off with 90w gear oil.
Thanks for the info.
Jerry...
JerryD is offline
post #9 of 10 Old 01-28-2014, 08:04 PM
Thumbs up
THE HOUSING OF THE GEAR BOX IS CAST ALUM. THE GEARS ARE A TYPE OF STEEL. FROM THE EARLY 70'S TO THE LATE 90'S THE GEAR BOXES HAVE STAYED THE SAME.
post #10 of 10 Old 01-29-2014, 08:31 PM Thread Starter
Likes (Received): 8
This machine absolutely has a cast iron gearbox on it. I did top it off with 90wt.
JerryD is offline
