Toro 824 throttle rod play. - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-05-2018, 04:05 PM Thread Starter
Toro 824 throttle rod play and some other fixing
First post in this forum
Bought a Toro 824 who wouldn't start. Thinking it would be an easy fix.
Bought a new carburetor and got it started at least. But the throttle goes up and down constantly. I have too much play in the throttle assembly it seems.
The governor arm goes back and forward constantly. I have searched on eBay for an hour and it looks like it's very hard to get any of the parts new.
Any idea for a quick fix of some kind?
I can provide some pictures later.
Edit: Found one for sale who have the throttle control next to the carb. Mine have the control on the top panel.
Hmm maybe it's easier to do this. Less moving parts. The throttle assembly seems more complicated than necessary anyway.
Rune Karlsen is offline
post #2 of 17 Old 03-05-2018, 04:43 PM
Likes (Received): 303
nvragan
post #3 of 17 Old 03-05-2018, 04:59 PM Thread Starter
I will take some pictures tomorrow.
Yes the throttle adjustment lever is on the handle bar.
There is a bracket on top of the carburetor where the throttle cable goes. One rod goes from the top of this to the governor arm and the second rod from the governor arm to the top of the carburetor.
post #4 of 17 Old 03-06-2018, 02:44 PM Thread Starter
Some pictures now.
The problem is that the butterfly connector at the top of the carburetor can move freely about 1/4 of the total possible movement even with the rods connected.
I Also tried to replace the spring on the throttle linkage without much difference.
If i put the throttle below half speed it stops.
Sorry for any bad English, just ask and i will try to explain better.
ID:	136409   Click image for larger version
ID:	136417   Click image for larger version
ID:	136425   Click image for larger version
post #5 of 17 Old 03-06-2018, 03:44 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
New? You mean a new to you machine, a new used snowblower?
The throttle going up and down, you mean the engine is speeding up and down? If so, that would be a dirty carburetor. If you don't think you can clean it properly, buy a new one from eBay or Amazon.
post #6 of 17 Old 03-06-2018, 04:37 PM Thread Starter
The carburetor is brand new if you look a little closer on the pictures.
I can see that the throttle shaft on top of the carburetor are moving too freely while it's running. Because there is to much play in the throttle assembly.
I will try to buy som different springs to se if that helps removing some of the play in the throttle assembly.
post #7 of 17 Old 03-06-2018, 08:43 PM
lkuo
Thanks Rune Karlsen thanked for this post
post #8 of 17 Old 03-07-2018, 03:52 PM Thread Starter
Thank you so much for the pictures. I will look at it tomorrow to see if i have got everything in the right place before i try anything else.
post #9 of 17 Old 03-08-2018, 02:09 PM Thread Starter
After som more work i finally got it running quite smoothly. I replaced the cheap spring on the throttle bracket with something little bit more expensive.
I also adjusted the governor arm. Seems like the arm wasn't properly connected with the small shaft it's mounted on.
Had a little intakte leak as well.
Still have some fine tuning to do on the carburetor. Seems like it running too high on full throttle, like the engine is resisting a bit.
I also noticed that the pulley that goes into the gearbox is quite wobbly as you can see on of the videos. Something that can be adjusted? The whole axle is moving so the pulley itself is not lose.
post #10 of 17 Old 03-08-2018, 02:14 PM
Thanks (Given): 26
Likes (Given): 83
Likes (Received): 240
Too tight a spring will cause it to overrev. The springs on those Tecumseh carbs are pretty soft - you might want to run the shop manual gov setup procedure using the original spring - it might work out after all.
And something is definitely wrong in the basement - that pulley is all over the place!
tadawson is offline
