Predatoro 521 newspaper shredder - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-06-2018, 12:44 PM Thread Starter
yoda's Avatar
Thanks (Given): 8
Likes (Received): 29
Ingested the neighbor's newspapaper a few weeks ago and it made horrible sounds as it was shredding and then killed the engine. Couldn't believe how cleanly it cut through the paper. Only damage was a stretched auger belt, which I had to replace.
It seems like a 29" belt should fit. Even with a new 29.5" belt I'm at the limit of adjustment. In other words, if this new belt stretches any, I have no more adjustment left.
With the increased HP of the Predator, the auger belt seems like the weak link. Any upgrades possible?
PredaToro: Toro 521, Predator 60363
yoda is offline
post #2 of 7 Old 03-06-2018, 01:13 PM
Likes (Received): 303
things I'd look at.
post #3 of 7 Old 03-06-2018, 01:42 PM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
I don't understand the problem? Put a different belt size on, if a 1/2" is too much, try a 1/4" difference. Belts over the net are cheap enough, $7 for a Kevlar, and Kevlar stretches less.
You can try a variable pulley. Search the subject under my name for my thread on it.
JLawrence08648 is offline
post #4 of 7 Old 03-06-2018, 05:21 PM
Thanks (Given): 60
Thanks (Received): 70
Likes (Given): 251
Likes (Received): 161
Don't you want the belt to be the weak link? Cheap and easy to fix/replace.
Paul
paulm12 is online now
post #5 of 7 Old 03-06-2018, 11:30 PM Thread Starter
yoda's Avatar
Thanks (Given): 8
Looks like the Kevlar belt is something to look into. I should be good for this year with a stock belt. I may take the auger and impeller assembly apart during the summer, just to make sure everything is OK. The gearbox has some slop in it, but the grease was full and looked clean.
yoda is offline
post #6 of 7 Old 03-06-2018, 11:48 PM
Likes (Received): 20
Wait....if you can adjust it out to be 29.5-inch, can't you un-adjust it back to 29-inch and put a 29-inch belt on it?
jrcjr is offline
post #7 of 7 Old 03-07-2018, 11:10 PM Thread Starter
yoda's Avatar
Thanks (Given): 8
That's what I plan to do. I have a used 29" belt around here somewhere.
yoda is offline
