Old Toro 726 is to fast, low gears dont work - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 03-13-2018, 07:16 PM Thread Starter
What can be the problem when i start to drive this rubber disc goes to the right and full speed ahead... i cant drive in slow speed, even when my lever is in 1 st gear, i tried tightening the nuts but dont work, how do i make the disc stay put!??
Thanks!!
Rilloo is offline
post #2 of 15 Old 03-13-2018, 08:09 PM
Thanks (Given): 563
Thanks (Received): 740
Likes (Given): 4195
Likes (Received): 1630
to SBF Rilloo
I'm not familiar with the shifter on that one. Up on the handle are there any detentes to hold the shifter in gear ??
post #3 of 15 Old 03-14-2018, 02:52 AM Thread Starter
Yes there is 3 place the gear is in for forward gear, and one for reverse.
Problem is even when i put it to first gear, i can manually slide the disc to the right side that means higher speed. It does this automatically when the engine runs.
Rilloo is offline
post #4 of 15 Old 03-14-2018, 06:58 AM
Thanks (Received): 372
Likes (Received): 1318
If I had to put any money down on it. I would say you is missing some parts up in there. looks like you might have to pull it all apart and have a good looksee at it all. here is the blow up of all zee parts in there. ALOHA from the Paradise City.
post #5 of 15 Old 03-14-2018, 08:50 AM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 437
When in gear, the friction disk should be making sufficient force against the friction plate that you wouldn't be able to move it by hand sideways. You have to find out why. Maybe it's getting hung up so you need to start disconnecting things. Try pushing things with your hands to see if something moves to apply the pressure.
post #6 of 15 Old 03-14-2018, 06:07 PM Thread Starter
Yes the friction disc cant be moved when engaged with the lever in let say gear nr 1 when the engine is not running.
When i start the engine and engage the disc it slides directly to the right and go for full speed. Even when the lever is in gear 1.
Dont know what parts could be missing? ��
Rilloo is offline
post #7 of 15 Old 03-14-2018, 07:17 PM
Thanks (Given): 26
Thanks (Received): 80
Likes (Given): 81
Likes (Received): 231
The disk should be hard linked to the shifter via the arm that is visible in your photo - IE the shifter should alter the position of the disk, and if the shifter cannot move, the disk should not. Thus, follow the linkage between the disk and it's sliding mechanism and the shifter on the handlebars - there should me zero to minimal slop . . .
tadawson is offline
post #8 of 15 Old 03-14-2018, 07:21 PM
Thanks (Given): 95
Likes (Given): 73
Is the wear on the rubber friction disk equal across or is one side of the rubber substantially more worn than the other side.
post #9 of 15 Old 03-14-2018, 07:58 PM
Likes (Given): 208
Likes (Received): 295
Do you know the model number so we can look at a parts drawing for how the shifter connects to the bellcrank we see?
dbert is offline
post #10 of 15 Old 03-15-2018, 03:39 AM
Check and see if the gear was switched oot to a smaller 1.
