no shear pins... every cause a problem? - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-15-2018, 11:44 AM Thread Starter
Likes (Received): 23
no shear pins... ever cause a problem?
Looking at Toro's and notice that they don't have shear pins, has this every caused a problem or just some slipping belts if it does grab something?
Is the claim of hardened gears real?
thanks
trellis is offline
post #2 of 17 Old 03-15-2018, 12:13 PM
Thanks (Given): 572
Thanks (Received): 746
Likes (Given): 4233
Likes (Received): 1650
to SBF trellis
I don't know about the gears being hardened but it does seem that the belt does slip before taking the gear box out. It doesn't seem to be a problem.
post #3 of 17 Old 03-15-2018, 12:13 PM
drmerdp's Avatar
Thanks (Received): 144
Likes (Given): 24
Likes (Received): 301
My buddy with a power max broke both “non shear bolts” last storm. Somethings got to give, but toro is confident it’s not going to be auger gears.
drmerdp is online now
post #4 of 17 Old 03-16-2018, 05:40 AM
Guest
Likes (Given): 48
yes they are hardened steel gears not a combo of brass and steel, and while they are grade 5 bolts i have broken a few and keep the
https://www.toro.com/en/parts/partdetails/?id=46475 auger bolt kits in stock contents are 2 each 5/16th auger and 1/4 impeller bolts, of the correct lengh 4 spacers and 4 lock nuts
old ope mechanic is offline
post #5 of 17 Old 03-16-2018, 08:19 AM
Likes (Received): 1344
Zee BLOODY MOTOR will stall oot. Because TORO DOES NOT use those BLOODY SHEER PINS!!!!!
post #6 of 17 Old 03-16-2018, 06:23 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 59
Likes (Given): 131
Likes (Received): 219
Yes . . . the problem is that every time I run over a stick or small branch the Toro sucks the thing up, obliterates it, and chucks it out in pieces. I ran over a newspaper under the snow once . .. forget about ever reading that paper
Also, I ran over a scarf once. . . the auger sucked the thing up. Upon removal, the scarf was about 10 feet long . . .
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #7 of 17 Old 03-16-2018, 06:34 PM
Guest
Likes (Given): 48
tod
take a look at the bolt. it has slightly smaller/thinner area at the end of the threads . while hard to do, they do break as designed to with the spacers and thinner thread end area as each one i have broken was right there where the thread ends
post #8 of 17 Old 03-16-2018, 06:55 PM
Thanks (Given): 572
Likes (Given): 4233
Originally Posted by old ope mechanic View Post
tod
That means they ARE a shear bolt
post #9 of 17 Old 03-16-2018, 09:10 PM
Thanks (Received): 93
Likes (Given): 38
Likes (Received): 248
Don't let Toro hear you say that. That would destroy Toro's claimed superiority over Honda and Ariens by not needing a sheer bolt because they have an industrial strength gear box ! LOL
RIT333 is online now
Likes Kiss4aFrog, detdrbuzzard liked this post
post #10 of 17 Old 03-17-2018, 10:58 AM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1849
Likes (Received): 644
I haven't broken a shear bolt yet but living on a mostly tree lined street I go take a look at the properties i'm going to be snowblowing so for the most part I know there are no objects to get sucked up by my toro ( s )
Likes Copper116 liked this post
