Toro Model 38802 Reverse moves Forward - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 03-24-2018, 09:42 PM Thread Starter
Unhappy Toro Model 38802 Reverse moves Forward
Hi,
I have a Toro Model 38802 Power Max Heavy Duty 1028 OHXE Snowthrower that I bought new in 9/2016
I finally had to use it for the FIRST time today.
I find when I put it in a reverse gear, it still just moves forward.
Any idea what could be wrong? Thanks
edporch is offline
post #2 of 5 Old 03-24-2018, 10:43 PM
Thanks (Received): 29
Likes (Received): 41
You can adjust the shift rod. Look under the dash you will see the trunnion at the end of the rod up on the shifter take the pin off that holds it turn it clockwise to shorten the length of the rod. Just go a little at a time till you have reverse but make sure 1st forward still works.
351beno is offline
post #3 of 5 Old 03-24-2018, 10:46 PM Thread Starter
Thanks, I'll try it.
edporch is offline
post #4 of 5 Old 03-25-2018, 12:01 AM
Thanks (Given): 573
Thanks (Received): 750
Likes (Given): 4247
Likes (Received): 1682
Here's a link to the service manual --> https://www.toro.com/en/parts/partdetails/?id=44493
Page 4-8 has a photo of the trunion and instructions.
post #5 of 5 Old 03-25-2018, 09:39 AM Thread Starter
Thank you for the info.
edporch is offline
