Toro 418ZE will not prime or start - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 08-20-2018, 03:49 PM Thread Starter
I was performing maintenance and cleaning on our 418ZE snow thrower and noticed that it would not start and no fuel was getting to the motor. The spark plug was dry.
I inspected the carburetor and noticed a small pin hole on the top of the carb where the primer bulb was. I put my finger on the hole and it primed and started.
However, after starting the RPM is erratic. If I put my finger on the hole the RPM is steadier.
Is this hole supposed to be there ?
tvr4 is offline
post #2 of 3 Old 08-20-2018, 10:44 PM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 177
You have a vacuum leak.
Where is the fuel tank?
Is the primer bulb still intact?????
Is it a black rubber button and does it have a hole in the center of it??
My Toro snow pups have to have a hole in the primer rubber in the dash to work properly.
Another example are my Stihl weedwackers, blowers and chain saws and my old Homelites where they have a solid primer bulb with no vent hole in the center to pull fuel up into the carburator to start them.
My Toro snow pups need to just start a brief vacuum to prime them start them as the tanks are such that it pulls the fuel down into the carburator.
leonz is offline
post #3 of 3 Old 08-20-2018, 11:58 PM
Thanks (Given): 58
Thanks (Received): 70
Likes (Given): 241
Likes (Received): 157
can you post a picture of the carb? showing the pin hole? And I agree with leonz, if the primer circuit is open, you will have a vacuum leak into the carb. Plugging the hole while running it should run well.
Paul
paulm12 is online now
