CCR 2000 Engine Removal - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-07-2018, 11:22 AM Thread Starter
I am working on a CCR2000 Snowthrower for a friends son. One of the engine bolts are sheared off and the other two are out. Does anyone know how to remove engine without disassembling the whole machine?
Thanks in Advance-
JoeyD212 is offline
post #2 of 5 Old 12-07-2018, 11:56 AM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1026
So sorry. I removed one years ago but I really don't recall how I did.it. Have you tried Youtube? Maybe try Donyboy 73 channel.
post #3 of 5 Old 12-07-2018, 12:48 PM
gibbs296's Avatar
Thanks (Given): 168
Thanks (Received): 68
Likes (Given): 1198
Likes (Received): 288
Just swapped motors on my 210r a month or 2 ago. It's actually pretty simple, the single stages just don't have that many parts. However it is pretty close to a total teardown by time you are done. Chute, hood, dash panel, switch wiring, fuel lines, belt, etc. On mine the engine drive belt pulley had to be removed before it would fit through the engine mounting bracket on the left side. Still a very simple job.
gibbs296 is online now
post #4 of 5 Old 12-07-2018, 01:20 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3328
Likes (Received): 677
Joey, welcome to SBF. Here is a link to the Toro single stage service manual. You should be able to find what you need. As gibbs said, lots of things to remove, but not that difficult to do.
https://www.scribd.com/doc/70707942/...-Blower-Manual
post #5 of 5 Old 12-07-2018, 02:09 PM
Thanks (Received): 80
Likes (Given): 75
Likes (Received): 276
can you weld to it without welding it to the body. i usually weld on the bolt to build it up a little first then stick the nut on and weld it on. so far it has worked. the other option would be drill it and try an extractor or drill it out and re-tap it
yardworks 31AH6WKF515
crazzywolfie is online now
