Differences between 828xle & 1028xle - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-19-2018, 02:58 PM Thread Starter
Just bought a 1028 xle was wondering if their are differences between a 828xle which I also own.Both machines are 8 years old.
Abcsnow is offline
post #2 of 10 Old 12-19-2018, 03:06 PM
Thanks (Received): 379
Likes (Received): 1377
More than likely just a different engine size. Anyhoo, ALOHA From The Paradise City.
post #3 of 10 Old 12-19-2018, 03:26 PM Thread Starter
Let’s try to look beyond the obvious, there looks like there could be a difference in the diff, maybe drive & auger belt?
Abcsnow is offline
post #4 of 10 Old 12-19-2018, 03:53 PM
Nope!!!!!!!!!!!!!!!! all running gear is the same!!!!!!!!!!!!!!!!!!!!
post #5 of 10 Old 12-19-2018, 04:36 PM Thread Starter
Does this mean I could swap the 10hp on to the 8hp model simply by switching them?
Abcsnow is offline
post #6 of 10 Old 12-19-2018, 05:28 PM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
1028 xle - 828 xle = 200 xle
so the difference is 2.00 . . . HP that is.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #7 of 10 Old 12-19-2018, 07:09 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 472
Likes (Received): 831
If you pull up the parts diagrams, you could check the part numbers for the engine pulleys, and the belts, for instance. If those match between the two machines (at least the belts; the pulleys might have to be different if the crankshaft diameters are different for the two engines), then perhaps you could just swap them.
But if the two machines use different belts, then that might make a straight-swap less likely. Unless perhaps the only difference was something like crankshaft height, in which case maybe the belts could get swapped over as well, staying matched up with their engines.
post #8 of 10 Old 12-20-2018, 08:05 AM Thread Starter
switched moters last night, simple as that
Abcsnow is offline
post #9 of 10 Old 12-20-2018, 09:47 AM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 275
Likes (Received): 171
How about that , the guys were right !!! Glad to hear it worked out well. Post some pics when you get the chance.
Paul
paulm12 is online now
post #10 of 10 Old 12-20-2018, 05:27 PM Thread Starter
Will I notice a difference between the two motors, maybe a little more guts at the end of the drive after the Plow has passed. The 8 worked good, but thought the 10 might have more authority, just thought I might change it up.
Abcsnow is offline
Likes Dag Johnsen liked this post
