2450 vs 210r - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-01-2019, 11:36 AM Thread Starter
gibbs296's Avatar
Thanks (Given): 161
Thanks (Received): 65
Likes (Given): 1158
Likes (Received): 272
2450 vs 210r
So my 2450 was going to be one of my go to machines. I installed new paddles, scraper bar, and it kinda sucks. The issue I have is in its paddle to ground clearance. The 210r and powerlight both pull forward nicely. Not my 2450. Wrong paddles? Older design? Any thoughts?
gibbs296 is offline
post #2 of 5 Old 01-01-2019, 12:13 PM
aldfam4's Avatar
Thanks (Given): 248
Thanks (Received): 46
Likes (Given): 697
Likes (Received): 128
I thought all single stage machines operated on the paddles pulling the machine forward from making contact with the ground and basically scraping the driveway clean. If this isn't happening, something is wrong.
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #3 of 5 Old 01-01-2019, 04:01 PM
Thanks (Given): 572
Thanks (Received): 746
Likes (Given): 4233
Likes (Received): 1650
What part number paddle and scraper did you install ??
There isn't any adjustment as the scraper just bolts on so it would seem it would need to be something in the fit between those two parts. With new paddles it should clean to the surface and slightly pull itself.
Any chance you have something worn in the wheels, wheel axle, axle mount allowing the machine to lean back more than it should ??
post #4 of 5 Old 01-02-2019, 12:41 PM
Location: Split between Manchester and Deep Creek Lake Md.
Thanks (Received): 8
Likes (Received): 20
On my 3650 you have to tilt the machine slightly forward for the paddles to pull it up the driveway.
toms is online now
post #5 of 5 Old 01-02-2019, 01:10 PM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1849
Likes (Received): 644
I had some aftermarket paddles on my 2450 that was causing problems. they are worn out ( wore out fast too ) now so i'm going to get a set of OEM paddles soon
