2015 826 OE: Auger will clog and stop spinning - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-02-2019, 08:56 PM Thread Starter
I've never had a problem with this snowblower. But today during a big snow storm with wet snow, my snowblower kept clogging. At the time I chalked it up to the wet snow. I cleaned out the auger and left it for a few hours.
But then the snow turned light and fluffy. Ideal stuff to work with. I'd initially get a good bit of power, then it would slowly die - unable to launch snow the more than 5 feet, then finally clog up and the auger would stop spinning.
Clearing out the auger and impeller didn't work.
Is a belt slipping? I noticed a smell, but never paid much attention to it at the time.
Anything I should check?
RCGA is offline
post #2 of 17 Old 01-02-2019, 09:26 PM
WVguy's Avatar
Thanks (Received): 42
Likes (Received): 165
Given the odd smell, the belt(s) would be the first thing I'd look at.
WVguy is offline
Likes Kiss4aFrog, Prime liked this post
post #3 of 17 Old 01-02-2019, 09:30 PM
Thanks (Given): 95
Thanks (Received): 193
Likes (Given): 73
Likes (Received): 444
Sounds like the belt is slipping. If If smells, it's smoking, the belt is now no good as it grips from the sides and is now slipping. Get another belt. You may need to go 1/2" smaller. Without the belt on, check to see if the auger is binding.
post #4 of 17 Old 01-03-2019, 02:13 AM
Thanks (Given): 571
Thanks (Received): 742
Likes (Given): 4214
Likes (Received): 1638
to SBF RCGA
I agree on taking off the belt cover and taking a look at the belt. Post a photo if in doubt. There is also a way to tighten up your belt if it's still good but stretched a bit.
It's also easy to grab the augers and see if they will spin. Maybe you broke a shear pin and just don't know it. It's easy enough to take the spark plug wire off and get a hold of each auger and see if they will spin on the shaft or if the shear bolts are missing. Some times the wet stuff is just too much no matter what. If you haven't done one yet a good remedy is adding an impeller modification. It really helps with the heavy wet stuff.
One of many threads on the mod with photos - - > https://www.snowblowerforum.com/foru...ler-mod-3.html
Likes foggysail liked this post
post #5 of 17 Old 01-03-2019, 05:31 AM
Thanks (Given): 7
Thanks (Received): 32
Likes (Given): 411
Likes (Received): 116
to SBF RCGA
mark
just a tiny reminder
I know your well aware ,that toro's don't use shear bolts ,
132619 is offline
Likes Kiss4aFrog, foggysail liked this post
post #6 of 17 Old 01-03-2019, 09:36 AM
SayItAintSnow's Avatar
Thanks (Received): 29
Likes (Given): 44
Likes (Received): 138
RCGA,
Based on your description of the symptoms, including the odd smell, as already mentioned by folks here with lots of experience, the smart money is on the auger drive belt slipping.
Not a big deal really....
Worst case scenario: The belt is all stretched out and you can't bring it into proper tightness, and so you'll need a new belt. A relatively cheap fix...
Best case scenario: You can adjust the tension on the belt by moving the idler/tensioner. The tensioner pulley may have even worked itself loose, and you just need to reposition it, and tighten it back up.
Either way, a pretty easy fix, and soon you should be back to being able to toss snow into your neighbors yard if you want...
--- Clint Eastwood
SayItAintSnow is offline
post #7 of 17 Old 01-03-2019, 10:17 AM Thread Starter
Here's a video I just took of the problem
Any clearer?
RCGA is offline
post #8 of 17 Old 01-03-2019, 10:54 AM
Thanks (Given): 95
Likes (Given): 73
Picture from the front showing belt slap?
post #9 of 17 Old 01-03-2019, 11:33 AM
Thanks (Given): 169
Thanks (Received): 304
Likes (Given): 421
Likes (Received): 1011
Replace the auger belt. Attack the snow just a bit less aggressively. Let the blower do all the work and maybe lower your speed. Less chance of belt slippage.
post #10 of 17 Old 01-03-2019, 11:41 AM
Thanks (Given): 571
Likes (Given): 4214
Originally Posted by 33 woodie View Post
mark
:facepalm_ zpsdj194qh I should know that since I have two. That's what I get for trying to think at one in the morning.
Likes micah68kj, jsup liked this post
