Governor Problems on Toro 1132 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-06-2019, 06:31 PM Thread Starter
Okay... Got my new carburetor and installed it. It doesn't leak. However, once the RPMs pick up it accelerates way too high and doesn't seem to govern properly. I noticed that the rod from the governor to the butterfly valve is custom made from what looks like a 12 gauge piece of copper wire. I'm wondering if anyone has a diagram of how the governor and rod and spring should be set up?
Russell Bantin is offline
post #2 of 11 Old 01-06-2019, 06:37 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
What engine is on your Toro?
SimplicitySolid22 is offline
post #3 of 11 Old 01-06-2019, 06:53 PM
Thanks (Received): 212
Likes (Received): 767
Check out donny Boy or Taryl.....some good info
cranman is offline
post #4 of 11 Old 01-06-2019, 07:01 PM
1132le's Avatar
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
http://www.barrettsmallengine.com/ma...alvemanual.pdf
page 29 figure 18 if its a ohv358cc tec
1132le is offline
post #5 of 11 Old 01-06-2019, 07:41 PM Thread Starter
11HP Briggs.. Powershift Model.
post #6 of 11 Old 01-09-2019, 12:05 PM Thread Starter
Here's the pick of the carburetor with a governor behind
post #7 of 11 Old 01-09-2019, 02:32 PM
Thanks (Received): 379
Likes (Received): 1377
There should be a spring that hooks from the throttle plate to the governor arm.
post #8 of 11 Old 01-09-2019, 02:40 PM Thread Starter
If by the throttle plate you mean the piece that moves the rod to the butterfly valve? then it is connected from the governor to that piece... Let me say this again... The throttle plate is the piece that rotates with the throttle? There's a spring from that to the governor
post #9 of 11 Old 01-09-2019, 03:00 PM
Yep!!!!!!
post #10 of 11 Old 01-09-2019, 05:25 PM Thread Starter
Yes it's there...
