1132 won't turn over - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-21-2019, 04:36 PM Thread Starter
Bought an old 1132 this weekend. Ran it before purhasing, started kind of hard and wouldn't pull start. I used it during yesterday's storm, and it started even harder. Runs like a top.. if it's running. And it'll pull start once it's been running for awhile.
Problem is, it won't turn over now and I may have burned the starter as nothing happens when I press the start button. I'd love to get this thing running well, it's a beast. What's the procedure to troubleshoot a starting problem with these machines? What does the hard (and now to NO) starting suggest?
Thanks all.
chrisinNH is offline
post #2 of 7 Old 01-21-2019, 04:49 PM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 477
Likes (Received): 836
Welcome to the forum! Difficulty in starting with the pull starter might be a fuel problem, or a compression problem, a spark problem, etc. What engine is it?
Have you done a compression test? If it's an OHV engine, you might want to check the valve clearances, though checking compression first is worthwhile.
Changing the spark plug is a cheap way to eliminate one possible ignition problem, anyways.
Will it start if you use starting fluid, or spray a bit of gas into the carburetor's intake? That might help show if you're having carb problems.
post #3 of 7 Old 01-21-2019, 05:12 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Let's clarify (again) since apparently the OP didn't read the terminology thread . . . .
Is "won't turn over" to imply the engine is siezed, as in won't rotate?
Or is in incorrectly referring to an engine that *will* rotate, but will not fire?
Please clarify . . .
tadawson is offline
post #4 of 7 Old 01-21-2019, 05:26 PM Thread Starter
Motor is B&S. Model is 38090.
Ah, yes, it will rotate but it won't fire. The starter was working, now it isn't. I may have burned it out. Regardless, I can't pull start it.
I think the spark plug was replaced before I bought it. It runs well if I can get it to run.
Looks like I should try some start fluid first.
post #5 of 7 Old 01-21-2019, 05:27 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
I believe that's an old 11hp Briggs flathead. Beast for sure!
could be weak spark (could be a points engine), low compression or you're just not getting a good enough prime (EDIT: My personal updraft briggs doesn't have a primer and easily pull-starts.)
have you tried a sniff of starter fluid? You'd have to get creative if it's the engine that I describe since the intake for the updraft carb is tucked way-up under the shroud/heat-box.
('87 Toro 38150 826)
post #6 of 7 Old 01-28-2019, 04:26 PM Thread Starter
Yes, that's the motor! No primer. I pulled the shroud and sprayed starter fluid. It started with ease. Am I into a carb rebuild?
post #7 of 7 Old 01-28-2019, 04:33 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1582
Likes (Received): 1670
did you check oil?
"It Feels Like Beer O'Clock "
orangputeh is online now
