CCR 2000E Carb Adjustment Help - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-22-2019, 04:34 PM Thread Starter
I have a Toro CCR 2000E that will only run with the choke on. I've cleaned the carburetor and also had a friend soak it and clean the jets. I suspect the problem is one of adjustment but I don't know how to do that and can't find any info on-line about it. The fuel filter is new.
Model No.: 38185
Serial No.: 900328
Model Year: 1989
Any help would be greatly appreciated.
Thanks,
RussFierce is offline
post #2 of 7 Old 01-23-2019, 07:37 AM
Thanks (Received): 7
Likes (Received): 19
Hello Did you remove the air mixture screw. Itís usually 1-1 1/2 turns out then you go from there. Thereís a lot to that little carb. You have to watch because times they will get a vacuum leak at the gaskets or linkage isnít in properly attached. Some things to look at when you reassemble. Attachment to engine and itís components. Sometimes they are hard to start after not being used in a while. Whatís the story on yours.
New Jersey, Toro 8/24, Ariens 5/22, small engine repairs
Bluejoe is offline
Thanks RussFierce thanked for this post
post #3 of 7 Old 01-23-2019, 08:04 AM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
Make sure all the gaskets are facing the right ones, and facing the right way. I had that problem on one of these machines, it could be confusing. I bet that is your problem.
Here's the replacement I purchased, that worked fine.
jsup is offline
post #4 of 7 Old 01-23-2019, 08:41 PM Thread Starter
It runs but only with the choke on. Where is the air mixture screw? I see a pilot screw.
Thanks,
post #5 of 7 Old 01-23-2019, 08:43 PM Thread Starter
Excuse my ignorance. How could a gasket be on backwards? Aren't both sides the same? If not how do I tell which is the correct orientation.
Thanks,
post #6 of 7 Old 01-23-2019, 09:13 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 275
Likes (Received): 171
I think that has the Suzuki motor with Mikuni carb. They are different than the Tecumseh carbs. Here is one video:
Paul
paulm12 is online now
post #7 of 7 Old 01-24-2019, 09:26 AM
Thanks (Given): 21
Likes (Given): 254
Thanks,
The gasket on the throttle plate side, if I remember correctly, has two gaskets that fit correctly. One leaves the entire face open, the other covers most of it, with a small hole. The second is the one you want. I'll get pics of the old carb later.
jsup is offline
