Rescue a CCR 3000 GTS? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-22-2019, 06:15 PM Thread Starter
First post!
I rescued a 3000 from a garbage pile this fall hoping someone was throwing it out for something simple. I brought it home, put some 40:1 in it, pulled the cable and I can't get it to start up. After several pulls it started leaking gas from the left side (where I think the carb is). This will be my first blower so I'm not all that familiar with them. Figured from what I read that it could probably use a carb rebuild and maybe that's what was causing it to spew gas? Don't really want to jump into it blindly, though.
Hoping someone can point me in a more educated direction. Where should I start to see if this thing even works?
MrMonkey is offline
post #2 of 9 Old 01-22-2019, 06:28 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
The carb is very easy to remove from that machine, and it's on the left side. The carb is leaking from a seal called a float inlet valve seat. Remove, buy a rebuild kit from the engine model number, not the snowblower model #, buy a can of carb cleaner however probably best to buy a $15 Chinese carburetor online. Drain the gas tank and line. Remember this is a 2 cycle. For regular use buy TC-W3 oil. You can spray some starting fluid in to the carb and see if it kicks. Check to see if it has spark.
Likes aldfam4 liked this post
post #3 of 9 Old 01-22-2019, 06:52 PM Thread Starter
Thanks for the quick response. Where would I find the engine model number? Only sticker I've found so far is a snowblower model number. Also, can't tell from your message if you're saying it is better to just buy a chinese carb or if a rebuild would be best. Can you clarify?
Also, without taking the carb apart where would I spray the starter fluid? Thanks!
MrMonkey is offline
post #4 of 9 Old 01-22-2019, 06:59 PM
Thanks (Given): 96
Likes (Given): 75
Spray the starting fluid in the carb throat, the opening you can see but if you are going to rebuild the carb, buy a can of carb cleaner and use that to see if it kicks.I
Rebuild or buy a Chinese carb? Do you want to use it this year? Buy Chinese. Rebuilding the carb does not mean the carb will be A-1. You may not even need a rebuild kit, you may only need a cleaning. To learn how to clean a carb, go to YouTube.
post #5 of 9 Old 01-22-2019, 07:10 PM Thread Starter
Awesome! And where would I find the engine model number?
MrMonkey is offline
post #6 of 9 Old 01-22-2019, 07:23 PM
Thanks (Given): 96
Likes (Given): 75
On the back of the engine facing the operator. Look underneath, bend over or stand the snowblower on the auger paddles. It's a sticky label. It will be visible though a flashlight helps.
post #7 of 9 Old 01-24-2019, 06:20 PM
Location: Split between Manchester and Deep Creek Lake Md.
Thanks (Received): 8
Likes (Received): 20
It should be a sticker that looks like this. This is from a Powerlite.
toms is online now
post #8 of 9 Old 01-24-2019, 07:21 PM
Thanks (Given): 96
Likes (Given): 75
That's the sticker for the machine, not for the engine, the engine has it's own sticker.
post #9 of 9 Old 01-24-2019, 08:46 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
my rebuild of a toro ccr
PT 1
PT2
PT3
AL DONE
MY VIDS ON FIXIN HER UP
vinnycom is offline
Thanks Fred9 thanked for this post
