Questions about changing paddles on 721QZE - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-25-2019, 06:54 AM Thread Starter
Question Questions about changing paddles on 721QZE
I just changed paddles/scraper bar on my 721QZE. Two questions:
  1. The paddles look "directional" - one side the rubber is thicker than the other. The instructions that came with paddles and the manual said nothing about which way to orient them. I ended up guessing the part with thicker rubber should be leading edge, just surprised I couldn't find any info about this, so not sure it matters.
  2. I tipped the machine back onto the handlebar in order to access the paddles and scraper bar for removal. When I was done, I found a nice puddle of oil on the ground. The manual said not to tip the machine onto its NOSE - opposite of what I did. Where did oil come from?
Its like a new machine with new paddles! I forgot how much of a self-propelling action there was when the machine was new. I feel like I need to hold the machine back in order to not have it run away from me!
djc6 is offline
post #2 of 8 Old 01-25-2019, 07:10 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
You can install them in any direction, but I remember reading the the rubber should be facing the front and the belts(threads) should face the rear of the auger housing when the auger is in the 12 o'clock position. I just found this video, at the 3:25 mark, he explains the orientation of the paddles.
russ01915 is offline
post #3 of 8 Old 01-25-2019, 08:25 AM Thread Starter
Thanks, thats the way I oriented the paddles (phew!)
Still curious where all the oil came from - guy in video has machine tipped back just like I did.
djc6 is offline
post #4 of 8 Old 01-25-2019, 09:25 AM
groomerz's Avatar
Thanks (Given): 11
Thanks (Received): 22
Likes (Received): 46
Oil probably came from breather tube
groomerz is offline
Thanks djc6 thanked for this post
post #5 of 8 Old 01-25-2019, 09:27 AM
groomerz's Avatar
Thanks (Given): 11
Just clean up oil and check oil level .
groomerz is offline
post #6 of 8 Old 01-25-2019, 09:32 AM
groomerz's Avatar
Thanks (Given): 11
Also FYI about paddles you got it right threads to back side. Rubber to the front On paddles there should be a small hole near working edge This is the wear indicator. When wear reaches hole time to replace paddles
groomerz is offline
post #7 of 8 Old 01-25-2019, 10:33 AM Thread Starter
Yes, it did seem to come from the breather tube. I did check/add oil when I was all done.
Any way to prevent this when I tip the machine back? I ask because was going to replace scraper bar/paddles on my dad's 721R next. Thanks!
djc6 is offline
post #8 of 8 Old 01-25-2019, 11:21 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Drain the oil, when done put it back in.
