Push nut size for 721e - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-27-2019, 12:02 PM Thread Starter
Had a wheel fall off this morning while clearing the driveway and the push nut was nowhere to be found. Anyone know what size nut this is? I’m in Canada and anyplace that sells the actual replacement part wants more than $50 USD to priority ship a $1 tiny piece of metal.
Daxproduck is offline
post #2 of 11 Old 01-27-2019, 12:07 PM
Thanks (Received): 379
Likes (Received): 1377
More than likely it is 5/16. if not than it is 1/4 Dia Rod. ALOHA From The Paradise City.
post #3 of 11 Old 01-27-2019, 12:15 PM
Grunt's Avatar
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3332
Likes (Received): 679
Welcome to SBF Dax. I just measured my axle and it is 1/2". Any hardware store should have them for less than $1.00.
post #4 of 11 Old 01-27-2019, 12:19 PM
YOU' "DA" MAN!!!!!!!!!!!!!! There BROTHER GRUNT.
post #5 of 11 Old 01-27-2019, 01:03 PM Thread Starter
Thanks guys! I will go grab a 1/2” and report back!!
post #6 of 11 Old 01-27-2019, 01:06 PM
Likes (Given): 215
Likes (Received): 304
I know Toro had a batch of pushnuts on the Powerclear that failed easily and came out with an improved version.
I'm waiting the hear back on how to determine you have a new and improved version.
dbert is offline
post #7 of 11 Old 01-27-2019, 01:46 PM
Grunt's Avatar
Thanks (Given): 275
Likes (Given): 3332
Original part on my Toro looks like the first picture, all steel cap. These have two contact points. The ones like the second picture with the plastic cap found on kids ride on cars and etc. seem to grab better because they have four or more contact points and can be driven on with a 3/4" (19mm) socket.
post #8 of 11 Old 01-27-2019, 01:59 PM
Likes (Given): 215
Talked to my local Toro dealer . He said that the new and improved axle push nuts look identical to the bad ones but have a tighter fit.
There is some document that he got along with a bag of replacement push nuts acknowledging the issue people were having with the wheels falling off.
dbert is offline
Likes Grunt liked this post
post #9 of 11 Old 01-27-2019, 02:07 PM
Thanks (Given): 7
Thanks (Received): 32
Likes (Given): 411
Likes (Received): 116
50 bucks for $1.57 part is unreal measure the shaft OD and find the canada ver of the usa tractor supply
132619 is offline
post #10 of 11 Old 01-27-2019, 06:43 PM
Likes (Received): 22
I push comes to shove, just thread it and put a nut on it.
If I can't fix it, I can screw it up so bad that no one else can either!
Greg13 is offline
