I bought a Snow Commander! - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-03-2019, 02:25 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
The back story is... I sold a CCR3650 to a local guy last month. When he came to pick it up, he said he had one just like it that recently died.
Fast forward a couple of weeks and I see a Toro snowblower for sale... It's a Snow Commander but the ad doesn't mention the model name or even the manufacturer, all it said was "Snowblower... needs primer bulb and electric starter doesn't work." - Turns out the seller was the SAME guy who bought my 3650.
We agreed on a price last night I brought it home this morning and just went through it. I installed a new primer bulb cover and cleaned out the carb. It runs pretty well! I removed the electric starter as the starter gear is trashed like every Toro single stage snowblower I've ever picked up.
The paddles are in ok shape and gets down to the pavement. Model #38602 from 2002.
I'm debating whether or not to fix the starter gear.
db130 is online now
post #2 of 10 Old 02-03-2019, 04:11 PM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 472
Likes (Received): 831
Very nice! Pretty funny that it's the same guy.
post #3 of 10 Old 02-04-2019, 10:24 AM
You should fix the gear I bought one for $12. One time I got to a customers house to do his driveway and my pull cord broke but thankfully he had an extension cord and used the electric start as a back up, it was a life saver.
Areins11528 is offline
post #4 of 10 Old 02-04-2019, 11:12 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
I agree with Areins11528, same thing happened to me, pull cord broke in snow on a 5hp, used the electric starter. Good to have a backup, Plan B!
post #5 of 10 Old 02-09-2019, 03:31 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 241
I went ahead with the electric starter gear replacement; also replaced the spark plug and fuel filter since the top shroud had to come off.
All it needs now to be 100% is to have its control panel support bracket (part number 104-0887-03) replaced. I found a used one for $25 which is now en route.
db130 is online now
post #6 of 10 Old 02-09-2019, 05:45 PM
Likes (Given): 1878
Likes (Received): 661
congrats, let us know how it compares to the 3650
post #7 of 10 Old 03-20-2019, 08:48 AM
Snowbelt_subie's Avatar
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
i picked one of these up last weekend man its a tank. the front pivot system seems like a bid of over-engineering tho.
the guy i bought it off of didnt know much about it and was going to put regular gas in it to show me it operate
i told him dont bother ill fix it if it needs it lol
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #8 of 10 Old 03-20-2019, 09:57 AM
Thanks (Given): 172
Likes (Given): 472
Yikes, sounds like you got there just in time! What's the front pivot system you're referring to? I've picked up some info on these, but not sure what that is.
I'm envisioning a beefier version of my 221, but with 3 paddles, not 2. There's probably more to it than that.
post #9 of 10 Old 03-20-2019, 10:10 AM
Thanks (Given): 20
Likes (Given): 59
They actually have 4 wheels and the scraper and bucket off the ground until you engage the auger. Then it pivots the bucket and scraper down to touch the pavement. Let off the auger engage and a spring pulls the bucket back up.
Sent from my SM-G950U using Tapatalk
post #10 of 10 Old 03-20-2019, 01:18 PM Thread Starter
db130's Avatar
Thanks (Given): 16
Likes (Given): 241
Nice pickup, @Snowbelt_subie! What year is yours?
I got this one all buttoned up and I got to use it once in heavy snow. It did OK but i the belt squealed a bit handling the EOD stuff. I readjusted the belt but have not used it since.
db130 is online now
