New to me CCR2000 - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-08-2019, 03:04 AM Thread Starter
New to me CCR2000
Hey all, the other day I just picked up a CCR2000 18180C, Not sure of the year but I think its somewhere around the late 1980's. It's in pretty good shape for its age and start first pull. I can't wait for our next snow fall so I can take it for a spin lol
Cheers, Rob
ID:	153117   Click image for larger version
ID:	153119   Click image for larger version
ID:	153121   Click image for larger version
Robob2367 is offline
post #2 of 14 Old 02-08-2019, 06:29 AM
Thanks (Given): 172
Thanks (Received): 335
Likes (Given): 472
Likes (Received): 831
Cool, enjoy! Does that have the Suzuki engine? Hopefully you'll get some snow soon!
Likes Robob2367 liked this post
post #3 of 14 Old 02-08-2019, 07:42 AM
Snowbelt_subie's Avatar
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
yep it has the suzuki. those things are light little powerhouse's. i am always on the lookout for 2000's.
i think the 2000's actually beat the 3650's in throwing distance in most conditions. but in heavy wet snow you will notice the difference in power.
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #4 of 14 Old 02-08-2019, 08:40 AM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
I'm digging the chrome handlebars, nice find.
db130 is online now
post #5 of 14 Old 02-08-2019, 12:42 PM
Thanks (Given): 102
Likes (Given): 273
Rob, they're great when they're running right, but when things are worn out and start to go wrong, the parts can be $$$$. I've owned two, one with electric start and one without. I bought the one with electric start for "cheap". Turned out to be the most expensive snow blower I'd ever own.
uberT is offline
post #6 of 14 Old 02-08-2019, 07:38 PM Thread Starter
Yup, it has the Suzuki motor in it! looks like I should get to try it out next week as long as the weather man isnt lying!
post #7 of 14 Old 02-08-2019, 07:41 PM Thread Starter
This one seems to be in good running order. Once spring rolls around ill probably give the carb a good cleaning and just go over everything.
post #8 of 14 Old 02-09-2019, 02:37 AM
Thanks (Received): 25
Likes (Received): 31
I completely refurbed a 2000E for myself and am very slowly doing a 3000E. The engines are pretty much bulletproof except for the CCR 2000 ignition module which is really the only component prone to fail after 10+ years. Mines a 1989 and has needed nothing other than carb cleanings. The frames on both were pretty well hammered so I junked everything but the plastic cover and the main frame but that's just 15-20 years of use, no fault of Toro's.
The mikuni carbs always clean up great. Parts are very pricey but you shouldn't need much. Maybe a bowl if rusted and the bowl gaskets. I don't think they have the same torque as the later 2450/3650 but they're far more pleasant to use (quieter). Plus the Briggs plastic carbs really are junk (finally went to metal around 08) and the engines seem to eat starter motor housings and pinion gears.
SnoThro is offline
Likes aldfam4 liked this post
post #9 of 14 Old 02-09-2019, 09:08 AM
Thanks (Given): 102
Likes (Given): 273
Yeah, it was the ignition components that were giving me problems. The engine/carb were fine.
uberT is offline
post #10 of 14 Old 02-09-2019, 01:59 PM
Likes (Given): 1878
Likes (Received): 661
congrats and nice find robob!! i'm still using a ccr3000E, seems quitter than my 2450 or 3650 but the 3000 seems to be down on power compared to the 2450 and 3650
Similar Threads
toro ccr2000 rebuild project vinnycom General Snowblower Discussion 53 11-21-2018 02:48 AM
CCR2000 leaks fuel caddydaddy Toro Snowblowers 5 01-24-2016 11:05 PM
CCR2000 paddles - OEM vs aftermarket bosco659 Toro Snowblowers 18 01-17-2016 08:23 PM
Toro CCR2000 won't start JohnMarsden Snowblower Repairs and Maintenance Forum 10 02-26-2014 08:29 PM
toro ccr2000 engine swap with a ccr3650 possible? bigggdaddy Snowblower Repairs and Maintenance Forum 3 01-12-2014 04:41 PM
